Reply
Highlighted
Occasional Contributor
Accepted Solution
Macro Advice Needed
Hello everyone. I am new to this forum and a reall rookie whenn it comes to photography.
I have a Canon EOS700D which I thinkmis called a Rebel T5i in other parts of the world. With the camera I use the follow lenses:
EFS - 18-55mm
EFS - 55-250mm
EF - 40mm
Recently I decided to have a go at some macro photography and thought I could do this with the existing lenses. But I find that I cannot get close enough with these lenses. Foolishly, I thought that the fact that they mentioned 'macro' on the lenses meant that they would be suitable for photographing small objects. I think I now understand that they can get close - but not close enough? I would be happy for anyone to correct or confirm this. Smiley Happy
So, I had a look for a macro lens and found that the cost was just too expensive for me to afford.
I then read that it was possible to reverse the lenses and use them in conjunction with an 'reversing ring'. So, I bought 2 rings to fit my lenses. However, it seems that the lens that I have wll not focu manually when not fitted the correct way. Rresumably because the lens does not recognise that the camera is turned on when the contacts are not meeting? So it seems that reversing the lenses will not work unless I work within some limitations of focusing using the zoom to the point where the object comes in focus. Again, limiting the effectiveness of the lens. The 40mm lens does not work at all in this case.
Now I have heard that you can buy 'close up' lenses to attach to the fornt of the lens which will magnify the existing lens making photographing tiny objects possible. These can be reasonably priced - especially if lesser known ones are bought. But even Canon ones are more reasonably priced than a true macro lens.
So......... can anyone tell me if the 'close up' attachments are worth buying? Will they work with the lenses that I mention? Or am I wasting my time and money once more?
Apologies if this question has been asked before, but I was hoping to learn more by entering into a discussion about what I am trying to do. As I said, I am pretty much ignorant about photography but as I now find myself with more time on my hands, I would like to get involved more and learn what  can do with my camera.
Highlighted
Moderator
Re: Macro Advice Needed
Hi Erskine,
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, to go: https://global.canon and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Highlighted
Esteemed Contributor
With modern electronic lenses, the tricks of reversing lenses and using extension tubes are gettingmore difficult or almost just as expensive as a dedicated lens.
I suggest you bite the bullet and get the EF-S 60mm macro.
Highlighted
@Porcha wrote:
Hi Erskine,
Many thanks, Porcha. I think this is the only forum though. Is that correct?
Highlighted
Many thanks, kvbarclay. I appreciate that. Especially if it saves me wasting more time and money to achieve nothing.
Great photo too.
Highlighted
VIP
"So......... can anyone tell me if the 'close up' attachments are worth buying?"
No, don't waste your money.  You need a real deal macro lens like the Canon EF-S 60mm f/2.8 Macro USM Lens.
"I had a look for a macro lens and found that the cost was just too expensive for me to afford."
It will be cheaper with much better results to get what you really need, a true macro lens.  You already wasted money that could be put towards one.  You can look in the Canon refurb store and of course there is the used market. Otherwise save abit longer to get the right lens.
Highlighted
VIP
"I think this is the only forum though. Is that correct?"
One of the advantages of Canon USA.  Smiley Happy  Where are you from?  There may be one there also.
Highlighted
Thanks for the advice. Fortuentely I didnt waste too much money on the reversing rings. However, I do hear what you are saying and have been looking at the used market following an earlier response.
I am in Scotland ans had a look on the Canon site for any links to a UK/Europe forum but did not fnd anything. I will try a more general search.
Highlighted
VIP
OK great.
If there isn't a refurb store in Scotland, you might see if Canon USA ships outside the US. Or, B&H sometimes has Canon refurbs for sale. You can check there.  They also have used.   The advantage is the Canon refurbs come with a warranty as new for a lesser price.  B&H and the other top web based retailers like Adorama, Roberts, etc also offer a warranty on their used lenses.
Highlighted
Moderator
Hi!  Just to chime in, all purchases made thorugh Canon USA require both billing and shipping addresses to be located within the United States.  We're unable to ship internationally.
Hope that helps!
powered by Lithium
