Lens Scratch, Disaster or No Big Deal?
bodacious5000
So I finally got an L lens and then put off getting a UV filter.  Dumb.  Anyway I got a scratch near to the center to of the front element.  Is this a big deal, or something that just happens and I should stop obsessing over it?  Is there any way to fix this?  Thanks.
6 REPLIES 6
cicopo
Unless you can see it in your images it's nothing to be concerned about. This might lessen the worries.
http://www.lensrentals.com/blog/2008/10/front-element-scratches
ebiggs1
Usually stuff on the front lens element is "out-of-focus" (OOF) and won't be seen in your photographs. But there is a reason Canon doesn't pre-scratch it's lens! It isn't good, so get the filter.
hsbn
Whiz
If i'm not mistaken, that lens doesn't have a hood. You can buy a knock off one for cheap off ebay. Lens hood is a better protection than UV filter IMHO.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
my 24-105 came with a hood.  I use it every time.  Well, nearly every time.  Good lens protection, though useless against improper wiping technique.  Also good for avoiding lens flare and increasing color saturation, which is the primary purpose.
You may find it hard to sell the lens someday on Ebay, but other than that you will probably never see any difference in your photos.  Don't use a cheap-o filter if you get a filter.
Scott
All 24-105 L come with hoods in the box.
A UV filter will degrade the image more than that tiny little scratch , your much better using the hood, even though its quite shallow. The only time I'd use a filter would be in extreme condition like a sand storm.
Others will disagree and say get a filter, well that's fine, but if you go that way make sure you get a good quality one and not a cheap bit of rubbish. I have B+W 77mm MRC F-Pro UV filters for when needed.
_____________________________________________________________
EOS 1D Mark IV, EOS 50D, EOS 30D
EF 24-70 f/2.8 L, EF 24-105 f/4 L IS, EF 70-200 f/2.8 L IS, EF 100-400mm f/4.5-5.6L IS
EF-S 18-55mm f/3.5-5.6 EF 1.4 II Extender
580EX MKII, 430EX MKII
"A UV filter will degrade the image more than that tiny little scratch ..."
I would much prefer to have the filter than that "tiny little scratch"!  But that's just me.
Enter for a chance to win!
April 20th-28th
