10-23-2019 02:45 PM
10-27-2019 05:03 PM - edited 10-27-2019 05:14 PM
I make my own decisions based on experience but don’t close my mind to the observations of others. Always willing to assess and learn.
I have the 70-200 f/2.8 II and the 70-200 f/4 II. Both IS versions. In real world images on 1D X at 10% crops difference is not discernible to me. Maybe test chart images would show a difference, but I don't shoot them.
For people that aren't printing wall prints, i.e. likely just sharing digital images, a different mind set is required. Just my opinion.
10-27-2019 11:44 PM
@jrhoffman75 wrote:I make my own decisions based on experience but don’t close my mind to the observations of others. Always willing to assess and learn.
One argument that favors the f/2.8 versions of the 70-200 over the f/4 versions is that the f/2.8 versions pair well with a 1.4x extender. The extender turns an f/2.8 lens into an f/4, which is usually acceptable. But it turns an f/4 lens into an f/5.6, which can be iffy, especially indoors.
10-28-2019 06:36 AM
I agree Bob. If money is not a limiting factor the f/2.8 version is the one to get.
But for the OP the $2000 price tag was limiting. That is why I suggested he look into a used f/4 version at about 1/3 the price.
10-28-2019 07:46 AM
Origianl poster here since someone needed to jump onto my initial question instead of creating their own chat for their issue
To clarify, my original posting did note about the 70-200 f/2.8. After extensive research and I've already had my mind set that the f/2.8 is the way to go and the f/4 would be possibly a waste of money and not perform as I want it to especially for indoor sporting events. If I need to save for the 6 months even for a used lens than that's what I'll do!
10-28-2019 08:35 AM - edited 10-28-2019 09:01 AM
For indoor sports, there is no question that the 2.8 version is the better choice. In addition to the 1 stop gain allowing a preferred mix of shutter speed vs high ISO noise, the camera AF system benefits from the faster lens and you will have a brighter viewfinder display.
And although I really don't want to confuse the issue further, there is life beyond a "zoom" lens and if you are shooting a lot of indoor sports with questionable lighting then don't overlook the possibility of the 135 F2 which is another stop faster than the 70-200 2.8 and it provides beautiful sharpness. I have shot quite a bit of volleyball and basketball with that lens and the price is very reasonable for a very sharp L series lens. I also use and love the 70-200 2.8 and have used it a lot for indoor sports also but there are times when that extra stop really helps and the cost of the 135 is far less.
For volleyball, basketball, and reduced field size indoor soccer, the 135 is a very useful length although with a crop body you would need to be a little further away which may be the case anyway if you don't have a court/field pass. Thursday night I was at a local high school to get photos of the senior night presentation but I took a few photos at some of the games prior to the presentation of graduating players and these were with the 135 F2. It is a medium telephoto so it allows a reasonably broad view of the action when desired but taking advantage of its sharpness and lower iso allowing F2 speed, it allows a tight crop when needed while retaining good quality. The first image is about a 20% crop while the second image is an entire frame capture by the camera, both shot from courtside with the 135MM fully open @1/640 and ISO 1600.
Rodger
10-28-2019 11:21 AM
"...shot from courtside with the 135MM fully open @1/640 and ISO 1600."
And both showing the extreme limits of DOF with a 135mil f2.
10-28-2019 11:25 AM
"After extensive research and I've already had my mind set that the f/2.8 is the way to go ..."
100% on board with you. The best is always the best and in the long run may be the cheapest.
10-28-2019 11:23 AM
"I make my own decisions based on experience but don’t close my mind to the observations of others."
Not saying you do, not saying you don't. It is just suspect when folks seem to always refer to some inner web reviewer in favor of their own experience. Perhaps it is because they don't have any?
