03-21-2015 08:55 PM
Hi. So I'm having issues with getting some pretty bad lens flare. Really strange issue
Shooting Canon 5D Mk. III w/ a Canon 24-70mm L series lens. I have a lens hood that came with the lens attached. When I shoot in landscape orientation, no issues. Yet when I sometimes shoot in portrait orientation, somehow the sun is hitting the lens giving me a bad flare. And this is at the 70mm end of the lens. No sun is in the shot, but somehow still getting crazy lens flare. And this isn't just one location but multiple locations throughout the day. Only when in complete overhead shade is there no flare.
I attached some examples.
I'm thinking, somehow, since the lens hood doesn't cover much when you shoot portrait orientation, that the sun is somehow shining from above and hitting the very bottom of the lens at an angle, causing this crazy flare. I can sometimes use my hand to block the flare as best I could, but obviously that's not an ideal solution.
Anyways, any ideas of what might be wrong. Is there something maybe wrong with the lens itself that is causing strange internal flare issues? Is the lens hood itself causing the flare somehow? Love to hear your theories and thoughts.
03-06-2016 03:01 PM
@Tomobil wrote:
Did you end up finding out what the issue was? My 5DMk3 is having the same problem.
"Yeah the lens is dirty, forgot to clean it. Was in a bit of a rush. I usually clean my lens with a lens cloth/shammy and maybe a camel hair brush for dust. Don't think it has anything to do with the coating being stripped, more think it's an internal optics thing."
Sounds to me like Ernie may have called it correctly in this case. Dirt. Your issue could be very different, though.
03-07-2016 09:44 AM
Usually dirt or dust or even smudges on the front of the lens will not effect it. But there is a limit. Excessive dirt can cause lens flare and other undesirable effects. That looks excessive to me.
03-07-2016 09:56 AM
@ebiggs1 wrote:Usually dirt or dust or even smudges on the front of the lens will not effect it. But there is a limit. Excessive dirt can cause lens flare and other undesirable effects. That looks excessive to me.
I think it depends on the nature of the smudge. In particular, whether it's of a transparent substance with a high refractive index.
03-07-2016 04:30 PM
"I think it depends on the nature of the smudge. In particular, whether it's of a transparent substance with a high refractive index."
I hope you don't mean like a low-pass filter.
03-07-2016 05:27 PM
@Waddizzle wrote:"I think it depends on the nature of the smudge. In particular, whether it's of a transparent substance with a high refractive index."
I guess I was thinking more along the lines of a Lensbaby.
