Reply
Highlighted
Occasional Contributor
Is canon EF 24-85mm F3.5-4.5 lens is compatible with canon eos 6D ?
Is canon EF 24-85mm F3.5-4.5 lens is compatible with canon eos 6D ? is it work fully automatic ?
Highlighted
Frequent Contributor
Re: Is canon EF 24-85mm F3.5-4.5 lens is compatible with canon eos 6D ?
Yes, that lens will work normally on the EOS 6D with all automatic functions intact. Any Canon lens labeled as "EF" will work on the 6D, but lenses labeled "EF-S" will have strong vignetting (darkening in the corners of the shot).
Highlighted
VIP
"Is canon EF 24-85mm F3.5-4.5 lens is compatible with canon eos 6D "
A better question might be, why?  It isn't a great lens and if I remember correctly was introduced for film cameras. It is probably in line with some of the "kit" lenses of today.
Highlighted
Esteemed Contributor
Actually... "EF-S" lenses will not even mount.  There's a lip on full-frame bodies designed to prevent EF-S lenses from being attached.  It's not just a question of heavy vignetting and severely degraded image quality at the edges of the frame -- there's a risk of the reflex mirror hitting the rear-most element on an EF-S lens (remember... full frame cameras require physically larger reflex mirrors).
Any "EF" lens can be used.  Any "EF-S" lens must not be used (and will not fit).  Also, there are a few special purpose lenses such as the MP-E and TS-E lenses which will work with the 6D as well.
Tim Campbell
5D III, 5D IV, 60Da
Highlighted
Tim is quite right. My mistake, sorry for the confusion.
Highlighted
 Thanks Pjmacd now I understand Any Canon lens labeled as "EF" will work on the 6D
regards
Highlighted
Thanks ebiggs1 for the valuable information
Regards
Highlighted
Thanks Tim now I know the difference between "EF_S" and "EF"
Regards
powered by Lithium
