10-11-2015 01:51 PM
10-11-2015 02:32 PM - edited 10-11-2015 02:41 PM
The 17-55mm f/2.8 IS. Moderate wide-angle to moderate telephoto. Fast enough for indoor use. Doesn't overlap the functionality of your current lens.
One caution: It's a big lens and will cast a shadow in the coverage field of the 7D's built-in flash. So if you get that lens, plan on buying an external flash sooner rather than later.
BTW, I see now that you're the same person who posted the same query a couple of days ago regarding a 6D. If that was a typo, my advice above stands. If your camera is actually a 6D, I concur with John Hoffman's advice in the other thread. And if you have both cameras, note that the lens I recommended for your 7D won't fit your 6D.
10-11-2015 02:47 PM
Me? I don't mind some overlap when it comes to lenses. Especially when it comes to zoom lenses.
Canon EF 28-135mm f/3.5-5.6 IS USM Lens is a good budget minded choice, and would still be usable if you upgraded to a full frame camera one day. Although my recommendation for a cropped sensor is the Canon EF-S 18-135mm f/3.5-5.6 IS STM Lens.
10-11-2015 03:49 PM
10-12-2015 09:35 AM
First let us be clear:
ef-s 17-55mm f2.8 is usm for the 7D is a great choice. It will not work on the 6D.
ef 24-405mm f4L for the 6D. It will work on either camera but may be a little less friendly for the 7D,
The ef 28-135mm is not an "L" lens but is probably the best buy in any Canon lens for what you get. It will work for either camera.
10-12-2015 04:43 PM
