02-09-2017 02:35 PM
Is this a normal result from this lens?
I looked at the other tread and this lens seems to be far more blurry than the ones posted.
I appreciate any help in determining the issue!
Thanks.
David
02-09-2017 04:09 PM - edited 02-09-2017 04:10 PM
Your issue is not sharpness it is contrast. Is there a fog or mildew on the lens?
Do you have any special style settings? Try using green square.
02-09-2017 03:09 PM
How close were you when you took this?
02-09-2017 03:49 PM
I was 5-6 feet away...full zoom...
David
02-09-2017 03:50 PM
Her's one with 70mm
02-09-2017 03:52 PM
The closest focus distance is 5 feet, you might be too close.
02-09-2017 03:52 PM
I could be wrong but the picture appears to be washed out (lack of contrast) but not exactly blurry?
I downloaded it and did a quick contrast and brightness adjustment:
02-09-2017 04:01 PM
Thanks....I tried that too.
Seemed like it should be clearer than that without any "fixes"
heres one from 8 feet
02-09-2017 04:11 PM
And get a better test target, like this:
http://www.bobatkins.com/photography/technical/lens_sharpness.html
02-09-2017 05:23 PM
You need to check your exposure. There isn't anything wrong with being blurry or I can't tell until exposure is correct. Your shots are over exposed.
