05-19-2016 03:36 PM
I need to photograph the moon in a way that occupies most of my 35mm FF frame without crop. Or bigger than the frame. I need a clear full moon with craters (no problem).
The image will be in portrait mode.
My test using a Canon EF 100mm macro L lens resulted in a very small image for my needs (image attached).
What lens do you suggest to produce a big image of the full moon?
Thank you very much.
05-19-2016 03:47 PM
1000mm or longer zoom. This image is with a 400mm + 2X on 1.3 crop sensor.
05-19-2016 03:52 PM
05-19-2016 03:53 PM
I think it would be more cost effective to use a telescope rather than a camera lens.
05-19-2016 04:09 PM
05-19-2016 04:16 PM
500 mm sigma on a T3i
05-19-2016 04:32 PM
@Cunha wrote:
Thank you but I don´t have access to a telescope. This is a one time use so I´ll try to use a lens from a friend (don´t know which friend ,-)
The question answers itself: the friend who owns a telescope.
05-19-2016 04:35 PM
Or you can rent.
You'd better hurry though, you only have 'till sunday. 8^)
05-19-2016 05:00 PM
05-19-2016 05:14 PM
The moon is 0.5 degrees.
I used Canon's Focal length comparator to see what the field of view (in degrees) was in the long dimension for various focal lengths
FL FF Crop
400 4.8 3.8
500 3.8 3.1
600 3.2 2.6
800 2.4 1.9
1000 1.9 1.5
1500 1.3 1.0
So even with a 1500 mm lens the moon will be only half of the long dimension of the frame
