02-15-2021 03:52 PM
There isn't any. I believe what you're speaking to is that a human is generally not in a 2:3 aspect ratio. And thus when shooting an image in portrait orientation, head at the top, feet at bottom, you have negative space on the left/right. Is that what you're speaking to?
For printing, it will depend upon the aspect ratio of the paper. Unless it too will be in a 2:3 aspect ratio, you'll have to crop.
Same for any other aspect ratio you capture in; some cropping may be needed.
If you want to absolutely maximize the resolution (if you're making seriouslly large prints), you can always do panoramas (e.g. take 3 or perhaps 5 landscape-oriented shots of the person). This requires special skills and/or dedicated pano equipment and tripods to pull off. And then you're subject will have to be very still the whole time.
02-15-2021 04:02 PM
Thank you, rs-eos. I appreciate your response. This is a new camera for me. Maybe the
old one was "simplier" and "easier"...too bad I don't have. It was a simple "point and shoot"
in the simplest way(s).
Again, Thank you
02-15-2021 04:05 PM
Have you tried turning the camera sideways?
You can also change the aspect ratio of the image and turn the camera on its side:
Also, note that your printer paper also has a fixed aspect ratio you might be fighting. Don't be afraid to use your scissors!
02-15-2021 04:16 PM
I don't understand "aspects" (ratio)
02-15-2021 04:34 PM - edited 02-15-2021 04:34 PM
I you want to capture images and do printing, you'll need to understand aspect ratio.
Its a ratio between the width and height of an image. For 1:1, the image would be square. Same width as height. For 2:1, it would be twice as wide as it is tall. kvbarkley's post above shows where to go into the settings.
I rarely will print my images. But when doing so, I typically do an 8 by 10 or 16 by 20. These are 4:5 ratios which are a bit more square than 3:2 which is the default what you're camera would capture.
So one has to be careful to not fill the entire frame in that 3:2 aspect ratio and expect everything to fit in that 8 by 10 (4:5). Example here:
The original image (gray and black squares) represent a 3:2 aspect-ratio image. But when wanting to out to a 10 x 8 (or 20 x 16) which is a 5:4 aspect ratio, you'd need to crop. So when framing stuff for printing to this size, I just remember to not include important stuff that would get cropped out.
02-16-2021 09:32 AM
"Which lense is best to have "person" shot, fill the entire screen for printing?
I have EFS 18-55mm and 75-300mm. Neither will do that."
Yes, they will. Either will do it? The problem is how you use them and how you edit the photos. There is no such thing as a lens that will produce a great picture without input from you.
