09-24-2018 08:28 AM
Hi All,
I'm new to photography & getting to grips with my EOS80D + 10-18mm. My interest is seascape/ landscape. I've noticed that in a large % of my images I have issues with lens flare even when I have back to sun or sun is not even in image or obscured by thick cloud. Is this a known problem. I've attached a sample image to show you the issue - this is a full size crop from a problem image. In this instance sun was in image which has exacerbated problem
Really appreciate any help - thks, John
09-24-2018 08:47 AM
That is not flare, that is cruft in the lens or sensor, it probably needs to be sent to Canon for cleaning.
09-24-2018 09:17 AM
Many thanks for you quick response. The camera / Lens is pretty much brand new so I am suprised it would be so dirty - I have had a UV on lens since new. Looking at the lens I can't see any dirt. Also I don't see such issues if I take shots inside etc.which makes me think its not lens or sensor dirt?
Thks, John
09-24-2018 05:15 PM
Check out this review by Ken Rockwell:
https://www.kenrockwell.com/canon/lenses/10-18mm.htm
Where he specifically looks for flare. I see no indication of what you are seeing.
(If the link gets scrubbed, google Ken Rockwell Canon lens and scroll down to the lens.)
09-25-2018 05:35 PM
I think it is scattering off of a bunch of particles. Besides, he says that he sees it when his back is to the sun, a hood won't help there!
09-25-2018 05:52 PM
@kvbarkley wrote:I think it is scattering off of a bunch of particles. Besides, he says that he sees it when his back is to the sun, a hood won't help there!
You don't have to have the sun in your FOV to get flare. All you need is a spot bright enough to reflect off the lens and then off the back surface of the filter.
Eight or ten years ago my main walkaround lens was a well made but optically challenged Sigma 18-50mm f/2.8. I couldn't trust it not to exhibit flare, no matter what direction I was facing.
09-25-2018 06:28 PM
In any case, that is not typical of the EF-S 10-18mm.
09-25-2018 07:17 PM
@john_star_man wrote:Many thanks for you quick response. The camera / Lens is pretty much brand new so I am suprised it would be so dirty - I have had a UV on lens since new. Looking at the lens I can't see any dirt. Also I don't see such issues if I take shots inside etc.which makes me think its not lens or sensor dirt?
Thks, John
Looks a whole lot like ocean spray to me. Did you change lenses at the beach?
Instead of thinking, try to be an objective observer.
09-25-2018 04:54 PM
@kvbarkley wrote:That is not flare, that is cruft in the lens or sensor, it probably needs to be sent to Canon for cleaning.
It looks like flare to me. Dirt on the sensor is usually less OOF and tends to be more prominent in light areas than in dark. I'd start by taking Ernie's advice to use a lens hood and no filter.
09-24-2018 06:44 PM
Try a lens hood.
