Reply
Super Contributor
Re: EF lens diameter of image field.
Thanks. I am aware of all that. But thank you very much.
The Zeiss Classic/Milvus/Otus DIF (Diameter Image Field) is 43mm (all lenses but the Otus 28mm = 43,3mm ).
My sensor is 0,8mm bigger than 43mm. An hair but, there is a tiny difference.
Where is Canon lenses DIF?
Esteemed Contributor
It is not specified, at least not that I have seen. It might be buried in a white paper on a specific lens. That is the nice thing about designing to your own mount.
Honored Contributor
I have never seen it specified. Possibly because Canon, unlike Zeiss, is manufacturing their lens for a specific camera system and therefore no one needs to know that property of the lens.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Super Contributor
Maybe .-)
Super Contributor
Possibly true.
Frequent Contributor
The TS-E 50mm f/2.8L Macro, TS-E 90mm f/2.8L Macro and TS-E 135mm f/4L Macro all have an image circle of 67.2mm.
Super Contributor
Yes I know .-) Amazing lenses. Thanks.
[ Edited ]
Hello, Cunha,
According to EOS Magazine, the image circle of an EF lens is 43.2mm and EF-S is 27.3mm. This article is about tilt/shift lenses, which have a much larger image circle.
https://www.eos-magazine.com/articles/eospedia/canon-tilt-and-shift-lenses.html
I hope this helps.
FD
Super Contributor
Thank you very much.
At last!
Be safe.
New Contributor
If their image circle is 43.2 it’s good enough to cover most pixels in a MF sensor (I.e. 44mm * 33mm)
I saw from some adaptor manufacturer that this circle is not constant across all lens. I think this number is probably the best possible scenario. It reported telephoto lens works better than wide angle, but I would think it should be the other way around.
powered by Lithium
