Reply
Occasional Contributor
Accepted Solution
EF-S 55-250mm f/4-5.6 IS STM No Image
[ Edited ]
Canon 70D works fine with other lenses, but with the EF-S 55-250mm f/4-5.6 IS STM only a very blurry image.  Can see and takes pictures of objects at about 1 inch distance but anything farther apart is blurry.  Help!
Re: EF-S 55-250mm f/4-5.6 IS STM No Image
What happens when you adjust the focus ring? Anything?
Reputable Contributor
Being an STM lens you will need to switch it to MF then hold the shutter button halfway before turning the lens focus ring. If you can get correct focus in this way but not when it is switched to AF then you very likely have a faulty lens.
Nothing happens when I adjust the focus ring.  There is a white blurry image that seems like it is adjusting, but it never does properly to the point that a clear image can be seen.
Thanks for your response.  I tried your method but still no image.
This is what I get from any distance farther than 1":
VIP
Is there a macro filter on the lens?
Yes: Macro 0.85m/2.8ft
VIP
That doesn't exactly sound like a lens filter.  A lens filter is something that can be temporarily screwed on to the front of a lens, A macro filter will allow you to focus on objects much closer to the lens than what you could normally do.   Being able to focus one inch from the lens is MUCH closer than the listed Miinimum Focusing Distance specified for that lens.
The price you pay for being able to focus so close is that you lose the ability to focus further away.  If there is a filter, remove it.
Thanks for your input.  There is nothing attached to the lens.  If I 'screw' the .43x wide angle comverter w/macro, then I am able to see the image.
These lenses were working fine previously.  This is a new sympthom and I am not sure if its operator error or physical damage to the lens.
powered by Lithium
