Reply
Highlighted
New Contributor
Accepted Solution
EF-S 18-55 IS II autofocus works only at some mm
My 18-55 lens's autofocus works only in 18mm and 50mm-ish. When it is not in those it retracts all the way up. I tested with another same lens and it worked. I forgot to test my lens on another body.
Highlighted
Valued Contributor
Re: EF-S 18-55 IS II autofocus works only at some mm
Sounds as though you have a broken flexible cable inside the lens, it would cost more to repair than it would to buy a new lens.
Highlighted
VIP
Try this, can't hurt at this point.
  1. Take the lens off of your camera.
  2. Put the lens in MF mode.
  3. Twist the FOCUS ring (the tip of the lens) all the way to one side (extend it). You may hear a click noise or two, this is good, but don't FORCE the lens.
  4. Twist the FOCUS ring all the way to the opposite side (retract it). Again, you may hear a couple of clicking noises. What we hope is happening is the focusing motor being put back into its proper place.
  5. Put the lens back on the camera.
  6. Put the lens in AF mode.
  7. Turn the camera on.
  8. Put the camera in AUTO or P mode.
  9. Take a test photo.
Highlighted
New Contributor
I tried the 9 step method. I am pretty sure now the flex cable is broken. I might repair myself after i buy another lens
Highlighted
New Contributor
Yes, i am pretty sure this is. I am going to repair it myself after i buy another lens
powered by Lithium
