06-07-2014 08:05 PM - edited 06-07-2014 09:55 PM
06-18-2014 11:33 AM - edited 06-18-2014 12:13 PM
@AlanRhodes wrote:Thank you all. I am going to send in the EF-S 10-22 to Canon and hope the cost is not too high to repair an already costly lens. I am buying a Tamron AF 17-50 mm F/2.8 SP XR Di II VC to have for this weekend sons grad party since my go to Canon lens for this type of family shots is out of serveice.
Feeling a little burned on the Canon lens, I paided the higher lens cost for the Canon expecting longer service and quality then I received. But since I am a novice I am going to give Tamron a try for my future business this go around.
Regarding the Tamron lens, the non-VC version is thought by most users to give better image quality than the more expensive VC version. And both versions do not have a USD focus system, which Tamron is starting to put on their more premium models and is similar to Canon's USM. So do not expect the same level of focus performance as you would typically see with a 10-22mm or the Canon EF-S 17-55mm, which costs more but also gives top quality IS and a slightly longer telephoto.
Frankly, the problem you have with the 10-22mm seems quite unusual. Not to defend Canon (they can do that themselves), but I rarely see any complaints about that particular lens. Most users are very happy with the 10-22mm, many consider it one of the best ultrawides made by anyone, and decentered lens elements are usually the result of a hard bump to the lens or heavy wear and tear on moving parts, or occasionally a manufacturing flaw. I would encourage you to not judge Canon lenses on the whole, or even this ultrawide model, based upon your bad experiences with this one particular copy of the lens.
For your purposes - family shots - an ultrawide lens wouldn't be my first choice anyway. I think most photogs would call a 17-50 or 17-55/2.8 a better choice. Taking photos of people with an ultrawide, they often end up too small in the image, or heavily distorted if the lens is used close enough to fill the frame. This isn't any fault with the ultrawide lens, it's just the nature of wide angle optics. There are reasons that portrait lenses tend to be short to moderate telephoto focal lengths. A standard zoom (covering slightly wide to normal to short telephoto range of focal lengths), such as 18-55, 17-50, 17-55 would be a better choice in most cases.
I'm sure ebiggs assertions about EF-S lenses have a lot to do with his use of several cameras that cannot be fitted with EF-S lenses. I do too... so I minimize the number of "crop only" lenses in my kit (but the EF-S 10-22mm is one of several exceptons). You don't have this limitation with a 60D, which can use both EF and EF-S mount lenses without any problem. That being the case, the EF-S 17-55/2.8 IS USM is likely a better choice for you. For close to the same money, it has better image quality than the 17-40L, as well as f2.8 aperture and a wider range of focal lengths. The only place the L lens excels over the 17-55mm is probably build quality... The 17-40L is likely a bit better built and sealed to resist dust and moisture.
There are not and never will be an EF-S L-series lens. This isn't in any way due to the quality of EF-S lenses. It is only because Canon's own definition of what constitutes and L-series includes a stipulation that they must be compatible with all EOS cameras past, present and future. By design, EF-S lenses are not usable on film, digital full frame, or digital APS-H crop sensor camera models. They are compatible with APS-C crop sensor models, which are the vast majority of DSLRs that Canon sells, beginning with the original digital Rebel and 20D models of 2004/2005.
Several EF-S lenses are top quality and offer performance that rivals or even sets the standard among all manufacturers. The 10-22mm is one of those (usually... a faulty copy such as yours is very rare). I'd also count the EF-S 17-55mm, EF-S 15-85mm and EF-S 60/2.8 Macro lenses among the very best in their respective categories.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
06-15-2014 06:25 PM
And the lens does this on both camera bodies? Yes? The lens is bad. It needs to be evaluated by Canon service to see if repair is feasible. Cost may be prohibitive.
06-15-2014 06:42 PM
06-15-2014 07:11 PM
Well all is not lost yet. Have it evaluated.
But remember anything made by the hand of Man can and will eventualy fail.
This is a good lens and is probably better than anything else in it's focal length. There are offerings from the 3rd party world but they will be no better QA wise or construction wise. I have the very same lens and I also like it very much.
06-16-2014 11:53 PM - edited 06-16-2014 11:57 PM
Your lens needs to go in for evaluation and repair. It looks like a badly decentered lens element to me. That requires disassembly and repair. No amount of fooling around with it or cleaning the contacts will make it work right.
It appears not to be a fault of the camera itself, especially if your other lenses focus correctly. In fact it's not really the auto focus system at fault, when part of an image is out of focus like that, while the other part (in the same plane of focus) is sharp. It's gotta be an optical fault within the lens.
Probably the reason it appeared to work differently ("better", but still not right) on another camera is because it was set up to use a smaller aperture, giving more depth of field that covered up some of the fault of the lens.
If, as you say, 90% of the images are bad... that implies the other 10% are okay. Check those and see if a smaller (higher f-number like 11, 16 or 22) is being used, rendering more depth of field. Otherwise, it might be a loose element or focusing group, that's finding focus one out of ten times, but failing the rest.
No matter, really. The lens needs to go in for evaluation and, if economically sensible, repair.
Alan Myers
FLICKR & PRINTROOM
06-17-2014 06:43 AM
06-17-2014 06:53 AM
Although the 10-22mm is a good lens I would prefer the EF 17-40mm f4 L. This is just my personal prefference but I no longer buy any EF-S glass. There has to be a very goood reason to break that rule for me. There is no "L" made in EF-S for instance.
06-17-2014 09:01 AM
06-17-2014 10:07 AM
You already know my answer.
"... I no longer buy any EF-S glass."
06-18-2014 08:12 AM
06-18-2014 08:26 AM
