EF 70-300mm lens has stopped working. Any ideas on what the problmen might be?
cser
9 REPLIES 9
jrhoffman75
Exactly what is happening/not working?
ebiggs1
A lot more info is needed.  If it won't AF, it is probably toast and is kaput.  Did you drop it or get it wet?
Assuming he can see through it, it is either the focus, the IS or the aperture, all of those scream "Send me back to Canon!"
cser
This is me replying back to everyone who responded. THANK YOU! Nothing happened to it. It was in the bag and I had not used it for a while. It just doesn't work. It isn't the camera because other lenses work. It almost doesn't seem to be getting power - it will not focus - I say almost because sometimes it makes a little sound like it is "trying" to work. I cleaned the connections... not sure what else to do...
jrhoffman75
Does it have a MF/AF switch. Cycle the switch a few times. If you are in MF can you turn the focus ring?
It does have the mf/af ring.  I will try it when I get home.  Thanks.
I cycled the switch.  The ring does turn in MF but not easily...  Feels/sounds like something in there...kind of gritty
jrhoffman75
Most likely needs service then. But, it may be less expensive to replace the lens. Give Canon service a call and see if they have a flat rate repair fee or can ballpark you a repair cost. Then, go to the Canon eStore and check out refurbished lenses.
Check out this thread.
http://community.usa.canon.com/t5/Lenses/Autofocus-not-working-18-55mm-lens/m-p/138114#U138114
Your lens just may have a similar issue.  If not, contact Canon service.  I agree, a new lens of the same type just be less inexpensive than a repair.  What does that say to you about the quality of the lens?
