Reply
New Contributor
EF 70-300 IS II USM Start-Up Noise
Hello All,
I have a refurbished EF 70-300 IS II USM I bought last year. Love the lens and its performance. However, occasionally on start-up it will make a kind of clicking or grinding noise. It functions just fine after that, and it doesn't do it every time. Is this something I should be concerned about?
Thanks!
Esteemed Contributor
Re: EF 70-300 IS II USM Start-Up Noise
Probably the IS, they tend to be a bit noisy. You can try turning it off and see if the noise goes away.
Hi Fotokatze,
As kvbarkley suggested, Image Stabilization on a lens can produce some sound since the lens is actually shifting lens elements based on the movement that the gyroscopic sensor detects. The IS from one lens will sound a little different than that of a different lens, since all of our lenses have a slightly different construction with a range of lens elements.
Try to turn off the IS by switching the slider on the lens to the O position. The sound should not persist in that case.
If you are uncertain about the performance of your particular lens, then you may wish to compare it to a similar display lens at your local camera store.
To find dealers in your area who might have similar items in stock for comparison, you can go to www.canoneos.com. On the bottom of the page click on WHERE TO BUY then select LOCATE A SALES/ SERVICE PROVIDER on the new page that loads.
Forum Elite
The IS is mostly likely the cause. It is the only thing that moves unless you physically move something.  However, it is a fairly quite noise.  Somehow your description of, "... a kind of clicking or grinding noise" seems a bit loud.
Did you purchased it directly from Canon, not a camera store?  It was a Canon done refurb not a refurb from another service center?  Was this a merchant on Amazon?
New Contributor
I bought it directly from the Canon Refurbished store.
I’m familiar with the slight IS noise as the lens works. The noise at startup is much louder.
Forum Elite
"The noise at startup is much louder."
Yeah, that would concern me. However, you said, "I have a refurbished EF 70-300 IS II USM I bought last year." It sounds like you may be out of warranty service possibilities. You have to be careful repairing a lens like this as it can quickly add up to more than the lens is worth. You might give them a call 1 (800) 652-2666 just the same and find out.
New Contributor
It’s still within the 1-year warranty period—I already confirmed that. Thanks for the feedback!
Forum Elite
Great, give'm a call. Smiley Happy
I am too lazy to go check mine, but I don't recall any "grinding". I think I would have remarked that. 8^) I got mine refurbished, too.
Super Contributor
[ Edited ]
Same here. Refurb I've had and used for years, and yes, you can hear it, but ever so slightly. But only when I'm focusing, not at startup and definitely no grinding.
powered by Lithium
