01-14-2021 01:13 AM
I was doing some deep cleaning with my lens and when I put the back panel back on and put it on my camera the aperture setting wouldn't change and it would even let me focus idk what I've done wrong.
01-14-2021 06:17 AM
When you say "deep cleaning" do you mean you dismantled the lens to clean it, if so then you have probably dislodged or damaged an internal cable.
01-14-2021 08:26 AM - edited 01-14-2021 08:28 AM
Please tell us what you mean by "deep cleaning". What did you clean it with?
What do you mean by "back panel"? Do you mean the plastic insert in the rear lens mount?
01-14-2021 09:25 AM
01-14-2021 09:40 AM - edited 01-14-2021 09:41 AM
There really is no reason to remove the plastic insert when cleaning the lens. It exposes the delicate electronic circuit board and connectors. My guess is that you may have damaged some of those electronics.
01-14-2021 11:15 AM
"...a water down glass cleaner..."
Not just a bad idea but a very bad idea. Water anything and cameras/lenses are not a good thing.
01-14-2021 11:25 AM
Unless you can see if you dislodged anything or let it alone for a long enough to see if it dries out, the cost of shipping alone will probably be more than a used 50mm f1.8 is worth to repair.
01-14-2021 04:03 PM
What were you doing, what conditions you were shooting in that required you to do a "deep cleaning" of your lens?
01-14-2021 04:56 PM
01-14-2021 04:58 PM
