10-18-2021 05:54 AM
Fairly new to photography. I bought the Canon R6, with the 25-105mm F4 L lens. I also have the 70-200 F2.8 L.
Do I need a 35 or 50mm prime in F2.8 or 1.4?
10-18-2021 08:39 AM
My 50mm f1.4 is far from my most often used lens but it is a lens I wouldn't be without. It is also the only non-Canon lens I use, I didn't care for the Canon 50mm f1.4 and after two trips to Canon for repair, the first under warranty, it got replaced with a Sigma Art 50mm f1.4 which I like more. Hopefully the RF version of the Canon 50 f1.4 is better constructed as are most of Canon's other lenses.
The 35mm f1.4 is also a useful lens but if you are only buying one of the two, I think the 50mm will be on your camera more. Zoom lenses are versatile and convenient but there are times when a fast prime is the best choice.
Rodger
10-18-2021 09:05 AM
I would use the zooms for a bit and them decide:
Is the zoom just too darn heavy in some situations?
Is 50 or 35 a focal length you use often?
Do you need a faster lens for some situations?
10-18-2021 10:54 AM
The obvious is of course you do. You need both! Seriously you don't really need either. You have the most commonly required zooms already. I suspose you can make a case for a faster lens then the fast primes would be the choice.
"...if you are only buying one of the two, I think the 50mm will be on your camera more."
I disagree with that. I would prefer the Sigma 35mm f1.4 Art. It is a fantastic lens, perhaps the sharpest lens made. Highly versitle and of all my, albeit few, primes left in my lens inventory, it gets used the most.
I also own the unique ef 50mm f1.2L. If you have to have a 50mil it is the one to get. I sold my Sigam 50mm f1.4 Art to buy the Canon 50mm f1.2L. Of course that is my personal opinion others may not and don't see it that way. Truth is I almost never use it. It is my enjoy myself have a good time shooting some great subject lens.
10-18-2021 03:44 PM
I have the 70-200 L and I have the 50mm 1.8, what I came across was the other day my friend showed up on a Harley Tricycle and wanted me to take photos, it was difficult to fit in without walking way back to fit her into the photo. My wide angle 10-18 was at home and I was upset that I didn't have that with me.
10-19-2021 07:24 AM
@Bitman wrote:Fairly new to photography. I bought the Canon R6, with the 25-105mm F4 L lens. I also have the 70-200 F2.8 L.
The advantage of buying a prime lens is generally smaller size and a larger aperture for better low light capability. Primes can also have better image quality since there is less compromise in design compared to a zoom lens.
The disadvantage is there is only one focal length. You need to zoom with your feet. That isn't always possible.
You have L-series lenses, so the image quality difference will be less, and if you aren't looking at L-primes it may be nonexistent.
Buy a roll of gaffer tape (it doesn't leave a sticky residue).
Set the lens zoom to 35mm and tape the zoom ring setting. Spend a period of time taking images. Do you like the results? Do you feel limited by only having an f/4 aperture?
Repeat after setting the lens to 50mm.
11-07-2021 01:34 PM
It seems glaringly obvious to me to ask what subjects you shoot!
Lens focal length and other factors (like max aperture) have a strong relationship to the type of subject. If you shoot mostly street photography a 'normal' field of view and fast aperture might be a benefit, but if you are going to shoot a wide range of subjects you are fine with the 24-105L IMHO.
