Reply
Occasional Contributor
Re: Canon Lens EF 70-200mm L F4 USM+ 2X L series extender
Yes, actually you are right... Smiley Wink
Yeah, this is clear, but thank you for warning for me. Smiley Wink
What do you think the EF 300mm f/4 L IS USM lens? This would be better for the IS, even if I lose a hundred mm-s...
VIP
"What do you think the EF 300mm f/4 L IS USM lens?"
I love that lens.  It is a buy and it works well with the 1.4x tel-con. That results in a 420mm f5.6 lens with IS.  A win, win win.
Without the tel-con the 300mil is very sharp and a fast f4.
[ Edited ]
Wowza, thats sound good! Smiley Happy Plus the 80D crop (1,6x), and final results absolutely fabulous!
VIP
"Plus the 80D crop (1,6x), and final results absolutely fabulous!'
Yup, good and bad!  You are looking at nearly 700mm equivalent there.  All the good is added but all the bad is added, too. Remember there is no free lunch in photography. You give to get. It will take some time and practice to get the best out of it.
Yes, you are absolutely right in this. Smiley Wink
Reputable Contributor
Re: Canon EF 300mm f/4L IS USM and 1.4X (was Canon Lens EF 70-200mm L F4 USM+ 2X)
[ Edited ]
Canon EF 300mm f/4L IS USM on APS-C camera (7D)...
Waxwing brunch
EF 300mm f/4L with EF 1.4X II teleconverter on APS-C camera....
Valley coyote
EF 300mm f/4L IS USM on full frame camera (5D Mark II)...
Red tail hawk flyby
Enlarged detail from above...
Red tail hawk detail
EF 300mm f/4L IS USM with EF 1.4X II teleconverter on full frame camera (5D Mark II)....
Black tail mule deer buck
Enlarged detail from above image...
Black tail detail
The Canon EF 300mm f/4L IS USM is an old model, first introduced in the mid or late 1990s I think... But it's still in production and still a great lens. The lens alone is right around 3 lb. and the Canon 1.4X only adds another half lb.... so it's all pretty easily hand held. It has fast autofocus and image stabilization to help with handheld shots (all the above except the mule deer were hand held... for that I used a monopod).
The 300mm f/4L is pretty darned sharp, even with a 1.4X teleconverter. The 400mm f/5.6L lens alone is probably sharper than the 300mm with 1.4X... It's a great lens, but the EF 400mm f/5.6L USM doesn't have image stabilization. I also prefer that the 300mm and a 1.4X teleconverter give me two different and useful focal lengths to work with: 300mm with the lens alone and the 420mm combo.
The 300mm f/4L IS USM also is one of the closest focusing of the Canon lenses longer than 200mm. It gets to almost 1/3 life size without any assistance, but can be made even closer focusing with macro extension tubes. (In comparison, many of the far more expensive super telephotos only manage 1/4, 1/5 life size or less.) This image of a spider is slighlty cropped, but was shot with 300mm f/4L IS without any added extension tubes (hand held, on APS-C 7D camera)....
Spider on fence post
I've used the 300mm f/4L extensively for sports and wildlife. It has a few very minor quirks. For example, notice the purple or magenta higlight in the hawk's eye above. That's common in specular highlights with this particular lens. It's super easy to fix, if wanted, in post-processing. I didnt bother fixing it in this image because I don't feel it detracts in any way.
As an older design, the 300mm f/4L also uses a more "primitive" form of image stabilization. It doesn't give quite as much "assistance" as some of the newer ones... maybe two to three stops worth (newer can give up to four stops). Still, the IS is very helpful. More importantly, the type of IS system this lens uses needs to be turned off by the user IF the lens is fully locked down on a tripod or being used in any other way where there's no movement for the IS to correct. When there's absolutely no movement, the IS in this lens can go into sort of a feedback loop where it's actually creating movement and can cause shake blur in images. So it needs to be turned off at the switch on the lens (most other Canon IS lenses self-detect and turn off IS automatically). Using this lens hand held and occasionally on a monopod or a "loose" gimbal on a tripod, I can't recall ever turing the IS off.
Overall, I like the 300mm f/4L enough that I bought a second one! My oldest one is down with some problems with it's IS system. That older lens was used extensively for many years, so I'm not surprised it needs some service work.
More recently I got the Canon EF 100-400mm L IS USM "II" and have been working with that zoom a lot for similar purposes. It is a bit bigger and heavier than the 300mm f/4. It's also a larger diameter which I find tires my hand holding it a lot faster during extended shooting sessions. As a result I'm more likely to use this zoom on a tripod.... Something I rarely have done with the 300mm lens. I've often shot with the 300mm hand held for 4, 6 or 8 hours, with just an occasional break.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
Thanks for this complex and detailed answer, you helped a lot. Presumably I will choose this lens.
powered by Lithium
