01-30-2019 01:37 PM
Hello, I'm writing from Italy. I would like to buy a very good 180mm macro. I shoot with a Canopn 5DS and I've read that Canon doesn't reccomend the 180L on a 50MP camera.
Does anyone have a first hand experience with this combo (5DS or 5DSr)?
I shoot details in ancient paintings so I need sharpness even on the edges.
Thank you
01-30-2019 03:11 PM
Where did you read that Canon does not recommend an L lens for a 50MP camera?
01-30-2019 04:10 PM
01-30-2019 04:12 PM
01-30-2019 04:45 PM
I see that that both 100mm macro made the list.
Obviously, it will work, it *might* be the limiting factor in resolution. What aperture do you usually shoot?
01-30-2019 06:12 PM
I usually shoot at f8/f9.
I have experience with the Canon 100 usm (not the L); it's an old lens like the 180, but I'm satisfued with the results. If the 180 macro is like the 100, it will be fine fine for me.
i know that the Sigma 180 os 2.8 is better for sharpness and resolutiin but it's really heavy
01-30-2019 06:17 PM - edited 01-30-2019 06:19 PM
At f/8 or f/9 it probably does not matter, the lens is improved by stopping it down and diffraction is starting to kick in, anyway.
https://fstoppers.com/education/5ds-f11-and-confusing-circles-68177
01-30-2019 10:03 PM
The combination of the EOS 5DS or 5DS R and EF 180mm f/3.5L Macro USM works very well, but I would only recommend this setup if you are using a tripod.
01-30-2019 10:43 PM
@PLee wrote:The combination of the EOS 5DS or 5DS R and EF 180mm f/3.5L Macro USM works very well, but I would only recommend this setup if you are using a tripod.
For the OP's stated application, he will certainly be using a tripod. When photographing paintings, both the perpendicularity of the line of sight and the angle of incidence of the lighting must be carefully adjusted to avoid weird reflections off of the paint. The brushstrokes of oil paint do not result in a planar surface, and getting the lighting right can be very tricky.
01-31-2019 02:46 AM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
