03-23-2015 04:31 AM
03-23-2015 10:17 AM
"Option 2: 24-70 f4L is + 70-200 f4L is + 100 f2.8 macro." ef-s 10-22mm.
03-23-2015 12:36 PM
03-23-2015 12:55 PM
03-23-2015 02:56 PM - edited 03-23-2015 03:06 PM
OK now you are really confusing me! Your original title asks, Re: Best gear lens on 70d
This is the correct answer to that querry. "Option 2: 24-70 f4L is + 70-200 f4L is + 100 f2.8 macro." ef-s 10-22mm.
If you stick with the 70D buy these lenses and try them out before you add to them.
"Will be replace to 5dmiii later on! "
Now the question is, I have a 70D now but I am going to buy a 5D Mk III soon? And if that is correct the correct answer is,
"Option 2: 24-70 f4L is + 70-200 f4L is."
You need to try this combo with a 5D Mk III first before you jump into other areas. On a FF, 24mm may be wide enough and 200mm may be tele enough. Plus this combo may focus close enough you don't need a macro.
There is no debate. This is my suggestion. It is worth exactly what you paid for it.
03-23-2015 12:38 PM
03-25-2015 08:29 AM
03-25-2015 09:34 AM
You are on your own,
Bob
Boston, Massachusetts USA
....have at it. He's a troll.
05-07-2015 06:13 PM
03-23-2015 03:08 PM
