02-25-2020 08:18 AM - edited 02-25-2020 08:26 AM
Hi all,
I have a Canon EOS M50. I just bought a multi adaptor and the EFS 24mm f2.8 lens because I want a wider angle and lower F stop. But it seems like the 24mm f 2.8 is not too different compared to the kit lens 15-45mm 3.5-6.3.
1. ) What is the most useful and effective wide-angle lens with a lower f stop or the EOs M50 for night photography? it seems the wide-angle EFS 24mm f2.8 lens works better on a full-frame.
02-25-2020 07:19 PM
@Obinna wrote:Is that what you use currently? is it good in low light? My mind is leaning towards the EF-M 22mm f/2 STM for low light/night photography and wide-angle honestly. what has been your experience for this purpose?
How much low light are you talking about? I shoot with an M3, and it is very good on cloudy overcast days.
It is also good indoors in rooms with average lighting. I haven't tried shooting in the dark, but I have used it to photograph the insides of IDF closets, panels, and racks with the 22mm. It does a very good job of it, but I do need a wider lens for that type of work.
02-25-2020 08:43 AM
Focal length is focal length. You had 24mm FL inside of your 15-45mm zoom. So at the same FL you will see the same thing.
IMHO, you will be far better off cutting your lose and buying a new camera. For instance the 90D. It will use native lenses that are made for it instead of adapting other lenses not made for the camera like you are trying to do now. You can get a true UWA lens like the Canon EF-S 10-22mm f/3.5-4.5 USM Lens or the Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens.
02-25-2020 10:37 AM
So what do you think about the 50mm 1.8 STM? does that make a remarkable difference for the EOS M50? Have you ever tried it out ?
02-25-2020 11:25 AM
The 50mm f1.8 is another great lens that is not designed to be used on a M50. It has to be adapted. a 50mm prime on a M50 will not be a friendly FL. It is a specific use FL not a general FL.
02-25-2020 11:44 AM
My 2 cents, for what it's worth.
The OP's EF-M 15-45mm f/3.5-6.3 IS STM has a variable aperture. It will only ever be at f/3.5 when it's at its widest 15mm, so it fits the bill in that sense. If it's zoomed in at all, you'll start losing light.
The EF-S 24mm f/2.8 STM is always going to be the same, so you'll get solid performance in low light as well as bright light.
The kit lens is wider, but you'll probably find the prime lens outperforms in dimly lit situations.
I have the 24mm STM lens and the 50mm STM lens, and I use them as my "walkaround" lenses on my T7i. I prefer the 24mm because it's wider.
02-25-2020 12:09 PM
Do you use an adapter for your ef 24mm f2.8 with your T7i?
02-25-2020 12:04 PM
02-25-2020 12:15 PM
02-25-2020 07:19 PM
02-25-2020 08:21 PM
Impressive!!! Thanks a lot. Was trying to make up my mind. I ended up buying it today
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
