Reply
Highlighted
Occasional Contributor
70-200 f2.8L photos too soft
I am facing IQ issues with all photos I am capturing with my 70-200 on a 5dm4. Even when mounted on a tripod under good lighting conditions, I can't seem to get crisp photos. They come out pretty soft. I am not sure if its my technique or if there is some issue with the lens. I've never had any luck with this lens since I bought it but I always attribted that to my T2i. I sent it to canon for repair few months back and they told me there is dust on the glass and the mount has scratches, which I think is total BS as I hardly used the lens.
Even after coming back from the "repair", I still get very soft pics. I will test the lens for front and back focussing to see if that's the reason, but sometimes I seem to be getting ok shots. I am not sure if I am expecting too much out of this lens. Reading online many people attest to the quality of the lens. May be I got a bad one.
Any suggestions on how I can make sure its not the lens that defective?
Link to some raw files - https://photos.app.goo.gl/mXL3rNktA21e1f2P8.
Thanks!
Highlighted
Honored Contributor
Re: 70-200 f2.8L photos too soft
I say there is nothing wrong with your lens. The flowers are nice and sharp.
What you are seeing is depth of field effect..
A lens can only truly focus at one distance from the sensor, called the plane of focus.
Depending on the lens focal length, the aperture (f/stop), and distance from the lens there is a region in front and behind of the plane of focus where the eye can still consider the image to be sharp.  This is called the depth of field.
A 200mm lens focusing that close to the flowers will have a shallow depth of field.
https://photographylife.com/what-is-depth-of-field
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
Thanks for the response.  I understand depth of field. In fact I took pics at f4, f5.6 etc (let me see if I can find those and upload), but I am not satisfied with the pics. I forgot to mention that I was using center AF point and focussed at the stamen of the flowers in the pictures. But the stamen when zoomed in (100%, 200% in DPP4) don't look too sharp.
Highlighted
VIP
Why didn't you manual focus?  Macro photography is something that you cannot rush.  You are on a tripod.  You can take your time to manually check focus, use shutter lockup, and even a remote shutter if you want.
A word to the wise.  Making AFMA corrections are easy to get wrong.  It will test you skill as a photographer.  It seems very simple and straightforward, which it ratty much is.  Just remember it is far easier to mess it up than it is to get it right.
I recommend taking at least a dozen test shots, and calculating an average result.  Defocus the lens between each test shot.  Your test shots should show a general trend, which is why you want to take many shots and calculate an average deviation from being spot on.
This means, of course, that you will want to take another series of similar test shots after making an adjustment to confirm the result of your changes.
Highlighted
Yes, manual focus sounds like a great idea. I uploaded only the macro photos but in general I am not too happy with my photos. Again I may be trying something that I can only master with lot of practice - like sports photography of my kids’ soccer and being really hard on myself 🤪. Some of my macro shots with lower aperture and shutter speed came out really good after I went back and checked them again. Maybe I am just being paranoid and need more practice.
I agree I need lot of patience and testing to see if I really need AFMA. Though I used -6 at the longer focal length and saw that the focus was almost perfect. Maybe it was a chance thing. But I will take lot of test shots just to be sure.
Thanks again for all the suggestions.
Highlighted
Reputable Contributor
[ Edited ]
Trying to assess sharpness by viewing at 200% is a complete waste of time because the software is just spreading the pixel information over a larger area than the natural resolution, there is no point in going above 100%.
Highlighted
True. Not sure what I was thinking.
Highlighted
VIP
The link you have does not contain any Raw files.  Just jpg with all the exif data stripped.
What exactly do you see wrong with this shot?
It looks pretty darn good ot me.  "...they told me there is dust on the glass ..." Unless it is severe, dust on the lens will not reduce IQ.
"Any suggestions on how I can make sure its not the lens that defective?"
If your lens took that photo, there is nothing wrong with it. You might let me have a look at the actual Raw file.
Highlighted
VIP
"But the stamen when zoomed in (100%, 200% in DPP4) don't look too sharp."
No kidding!  No lens does, don't do that.
"Making AFMA corrections are easy to get wrong."
Very true and most "L" lenses do not need it. Keep in mind AFMA does not make you lens one bit sharper. Nada, none! When it is needed, it is needed but make sure it is by doing a focus test. Not on a flower but on something like a yard stick.
If a lens is truly defective everything in the shot is OOF. Discounting camera motion of course. If it just needs AFMA than something in the photo will be in focus. Something either just in front of the focus point or directly behind the focus point.
Highlighted
I agree. Some of the pics of my son shooting soccer ball had the focus in the front. So I suspected the lens was front focusing. I think the problem was that he was moving towards me and the camera had trouble locking the focus. I will perform more controlled experiments before concluding that’s it’s the lens.
powered by Lithium
