03-01-2021 11:40 PM
I have a canon 300mm F4L IS lens That Shows the lens info [X] Canon EF300mm f/4 IS in the EXIF Files. Has anyone seen this before or know if it means anything?
03-02-2021 12:48 AM - edited 03-02-2021 12:48 AM
Your screenshot shows "Canon EF 300 f/4L IS". It seems to left off the "USM" part of the model number.
03-02-2021 09:15 AM
My EF-S 18-135 shows up fine in Photos and Preview. Have you tried the inspector in Preview? Have you tried DPP?
03-02-2021 11:01 AM
It shows up the same way in inspector. My other lens show up correctly in photos and inspector.
03-02-2021 11:06 AM
I believe that the EXIF info is just a code and the EXIF software has to translate it. In this case, it looks like the Mac is translating it wrong. I would guess that DPP would be correct.
Send feedback to Apple:
https://www.apple.com/feedback/
for MacOS.
03-02-2021 10:22 PM
You are right it shows up correctly in DDP. This is a older lens I bought off of ebay. Could that be the reason its not showing up correctly in preview, photos and the exif online data viewers?
03-03-2021 09:21 AM
It is just what Apple displays when it sees that code in the Exif, Apple has to change it.
