11-24-2015 09:15 PM
Does the built-in 1.4x extender make the lens 280 - 560mm or is the extender to get the 200-400? Thanks.
11-25-2015 09:46 AM
"Does the built-in 1.4x extender make the lens 280 - 560mm or is the extender to get the 200-400?"
The lens is a 200-400 is a 200-400 is a 200-400 and will always be a 200-400. It can not change its physical focal length after being made. The 1.4x gives it the appearent AOV of a 280-560.
A 1.4x Extender simply multiplies the effective lens focal length by 1.4x.
11-24-2015 10:54 PM
Your first set of numbers are what it becomes.
11-25-2015 09:46 AM
11-25-2015 09:57 AM
Thanks guys for the help. I wasn't sure on that.
11-25-2015 01:21 PM
@ebiggs1 wrote:"Does the built-in 1.4x extender make the lens 280 - 560mm or is the extender to get the 200-400?"
Or to put it more familiar terms: The [effective] focal range of the lens/extender combination is 280-560 mm. (I say this with no intent to denigrate Ernie's often-expressed preference for AOV as the figure of measure. It just isn't the way most users are programmed to see it.)
11-25-2015 12:12 PM - edited 11-25-2015 12:12 PM
The EF 200-400mm f/4L IS USM Extender 1.4X is a high-performance super telephoto zoom lens with an optically matched built-in 1.4x extender. With a flick of a switch, the zoom range can be quickly increased to 280-560mm (f/5.6).
12-02-2015 02:23 PM
