Reply
Highlighted
Frequent Contributor
10-18mm on an APS-C
I'm looking at buying a lower power lens for my 7Dmk1. My lowest zoom currently is my 18-55mm kit lens, and even with it , it leaves me wishing I could zoom further back. I've seen a ton on the 10-18mm for sale on the Marketplace, and all will usuly say, hardly used, or like new. Telling me maybe they aren't quite the lens they hoped for. Case in point, I hiked up to an old place I loved to go near Mt. Baker here in Washington, called Nooksack falls. It's a beautiful overlook but the quarters are tight to get a decent pic of the falls without having the safety fence in the frame. Or would a fixed prime lens of lower power, or a decent wide angle? I've got a cheap "accessory" wide angle adaptor that screws on the 18-55mm but being 1.4 it leaves the typical vingette from the extra distance of the adaptor in the frame. So what is everyone using for APS-C cameras, and low power or wide angle that won't break the bank. I would of had a beautiful b**bleep**bof the falls had I been able to get further back of had a wide angle lens.
Highlighted
Reputable Contributor
Re: 10-18mm on an APS-C
Get the Canon EF-S 10-18mm STM. Don't let the low price or availability fool you. It is a very good lens that that takes great photos.
Mike Sowsun
S110, SL1, 80D, 5D Mk III
Highlighted
VIP
I am not sure what "Marketplace" you are referring to, but I hope it is not Facebook   Just be aware there are always risks associated the buying used gear directly from an owner.
Highlighted
Esteemed Contributor
[ Edited ]
@iggythetiggy...
If you are going to purchase a ultra wide zoom...
Buy the 10~22mm over the 10~18.
And..  follow the guys advice on buying used and the source.  Canon refurb is always a good way to go.
And here you go:
https://shop.usa.canon.com/shop/en/catalog/ef-s-10-22mm-f-35-45-usm-refurbished
~6D2 ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100
Highlighted
VIP
Another option is to shoot several shots each overlapping the previous one by 25% or so. Edit them into a panorama. You can get it as wide as you want. If three shots isn't enough do 4 or 5 or 6 or how ever many you need.
Throw the accessory add on WA converter in the trash. Because that is what it is.
This is a pano I did because I could not get back further and didn't have a wider lens. It is three shots stitched together in Lightroom.
Highlighted
I was thinking of that, but a waterfall is too dynamic to stitch. Yours only worked because the band was standing still. Could you do it a minute later when they were marching?
Highlighted
VIP
The two choices in a UWA zoom lens are;
Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens and  Canon EF-S 10-22mm f/3.5-4.5 USM Lens. There is over a hundred dollar difference in price so what does that get you?
The Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens gives nothing up to the Canon EF-S 10-22mm f/3.5-4.5 USM Lens in terms of sharpness, they are neck and neck. Actually the Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens displays a more uniform sharpness when you compare it with the Canon EF-S 10-22mm f/3.5-4.5 USM Lens according to the tests I have read. I have neither nor have I used either one. Just reading the charts.
The EF-S 10-22mm f/3.5-4.5 USM Lens has a bigger objective at 77mm than the 67mm of the EF-S 10-18mm f/4.5-5.6 IS STM Lens.  Because it is more difficult to make a sharp, faster, lens with a larger front end, the EF-S 10-18mm f/4.5-5.6 IS STM Lens scores slightly higher in resolution. Now in real world will yo usee this?  No, I doubt it so it boils down to, is it worth $100+ bucks for almost a stop faster lens?  Remember you get IS with the  EF-S 10-18mm f/4.5-5.6 IS STM Lens and you don't with the EF-S 10-22mm f/3.5-4.5 USM Lens.
My choice would be buy the Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens, save the hundred bucks and love the IS.
Highlighted
VIP
"... but a waterfall is too dynamic to stitch."
That is a point that would have to be dealt with.  And, it would depend on what result you are after.  The flowing water could make a dramatic shot.
"Yours ... worked because the band was standing still."
Mostly still is correct.  But not motionless. They are playing the Banner and alma mater.  However, most of that motion was to the front and not to the sides which could present a problem. Obviously if they were in the middle of a drill or diagonal I could not have done it. But no procedure is ever a 100% in photography, only solutions. Which is what makes a good photographer vs the .......
Highlighted
I'll definitely give both a good look over. And I planned on being a refurbished I was just alarmed at the amount on FB Marketplace for sale thinking maybe this isn't a good lens, why I wanted to ask before ordering one up from Canon. I learned my lesson buying used even from a friend. My 28-135 had issues and had to send it in for repairs and ended up spending what a practically new one cost after I got it back.
Highlighted
VIP
Your lens an the Canon EF-S 10-22mm f/3.5-4.5 USM Lens are of the same build class of lenses. Meaning the build quality. The Canon EF-S 10-18mm f/4.5-5.6 IS STM Lens is in more of the beginner class, if that makes any difference to you. IMHO, of course.
powered by Lithium
