08-07-2016 05:33 PM
Got my Canon 220 Lide today.
Say i want to scan 5 A4 documents.
I open IJ Scan Utility and select "Document".
Once it has scanned, it asks if i want to "Exit" or scan another document by selecting "Scan". Ive got more documents to scan so i select scan.
After repeating this for my 5 documents i hit exit.
It opens My Image Garden HOWEVER only the first item i scanned is there (and only that item is in my chosen destination folder)
What am i doing wrong? Where are my other items! Any time i search for help online it thinks im referring to scanning multiple items at once.
Any help would be much appreciated! Thanks
08-08-2016 06:55 AM
Are you sure the five documents didn't get scanned into one file?
08-08-2016 08:07 AM
I just checked and you are right! Thank you! All documents are in 1 PDF.
So is there anyway so scan multiple documents (to separate files!) in one session or would i just have to click "Exit" (after each scan) then start the document scanning process again?
Thanks again!
08-08-2016 08:08 AM
I think there is an option in setup to scan multiple items into one or separate documents.
09-13-2016 03:07 PM
Aftrer scanning your document do you have the choice to save the scanned document? At the bottom of the "Save" or "Save As" dialog is it saving as a PDF by default? If so you should have the option to save in another file format like JPEG or TIFF. That should save each of your scans as a seperate file.
