Reply
Highlighted
Occasional Contributor
Re: Print Studio Pro mac osx 10.15 Catalina error
Great advice, I'll probably do the same
Highlighted
New Contributor
hey, apple's bonjour just rolled out an update to support canon printers. I was able to print on A3+ last night, no thanks to canon.
Highlighted
Was you able to use Canon Print Studio?
Highlighted
New Contributor
In an other thread, the following solved the issue (at least for me) with Print Studio Pro and Catalina:
https://community.usa.canon.com/t5/Professional-Photo-Printers/Print-Studio-crashing-from-Photoshop-...
Highlighted
New Contributor
Hi, I have a question regarding "Remember to disable the printer's color management in the print settings dialog box".
My OS is 10.15 Catalina
Im using Photoshop 21.0.0 Release
For Printer I choose "Canon PRO-100 Series"
For Color Management I'm using "Photoshop Manages Colors"
For Printer Profile I'm using "MOAB Lasal Photo Matte Pro-100 MPP.icc"
My Issue - Under color Management it says to "Remember to disable the printers color management in the print settings dialog box". However there is know where to disable this setting, or turn it off.
Where do I turn this off please? Is the drive I'm using the issue?
I've attached a screen shot of my "Print Settings" Dialog box so you can see there is no where to turn off. Print Settings.png
Highlighted
Paul, go to the Print Setting dialogue box Printer Setup when you first attempt to print. In the dropdown is "Color Matching". You'll see ColorSync greyed out. This indicates that PS is managing color not the printer. As a way of testing this select Printer manages Color and revisit the Print Settings option. You'll see you have an option to change what was previously greyed out.
Hopefully this helps. Make sure you screen is calibrated orr you may get different results from the prints. Screenshot 2019-12-10 at 21.15.52.pngScreenshot 2019-12-10 at 21.15.52.png
Highlighted
New Contributor
It is now January 2, 2020.  Any idea when Print Studio Pro will be available for the Pixma Pro 100 printer being used with Lightroom on an iMac with MacOS Catalina - version 10.15.2?
Highlighted
New Contributor
still no updates. really frustrating.
Highlighted
New Contributor
[ Edited ]
Canon, please advise when the anticipated date for 10.15 Driver release is. It is frustrating with all the work arounds I am requred to do. Im currently usling older work stations I had to bring up from storage. I hope you are a company that does not contribute to our global environemntal crisis by producing equipement that is rendered usless due to lack of software only. I cannot afford much more time with my current workflow and will be forced to look elswere for my printing requiremts if not rectified in short order. Thanks for listening.
Highlighted
New Contributor
I am having the same issue.  I called Canon last November and was told the software should be updated for Catalina by December.  I have checked each week, but so far nothing is available.  I called Canon support today and was told this issue is their number 1 complaint, but was told they do not know when or even if an update will be made to run on Catalina.  But I was told Canon did update the software to run on Windows 10, which is a 64 bit OS.  I guess this is just another example of Canon's lack of support for Apple product users.  I know this will be last Canon printer.
powered by Lithium
