Reply
Occasional Contributor
Re: MP Navigator X and macOS Mojave
i wish i can revert back to my old OS...sigh.....
don't make me go to Amazon and buy another printer...
Just found the latest version MP Navigator EX ver 2.1.6 and drivers in the Canon Australia site -- which are 64 bit versions as reported by High sierra system report. Working fine. So should be okay with Mojave
[ Edited ]
thank you!!  I literally copy and pasted your recommendation onto google search engine.
showed up HK site, I was thinking.. it is about the same region, gave that link a try.
link:
https://support-hk.canon-asia.com/contents/HK/EN/0200572632.html?
worked fabulously...(BTW, i have Mojave OS)
I had to turn on and off of the printer in order to reset itself, just FYI for an additional process to make a seamless solution.
absolutely resolve this 32~64 bit issue!!
thank you again!!!
This 2.1.6 does not work with Canon MG8220 printer scanner.
Did you use the link from above?
i have the MX 860, which also is a printer/scanner/fax
[ Edited ]
I used the link. This driver is only good for 3 printers and one scanner.
New Contributor
[ Edited ]
I have MP Navigator 5.1 installed on my Macbook Pro 2017. I just upgraded to Mojave. The application no longer will appear on my desktop when I try to start it. I don't believe there is a new version of the application and I have verfified that all drivers have been installed. Is there a way I can get the application to work?
I have Pixma MP432 printer
I tried IJ Scan Utility Lite and it worked. I liked MP Navigator better because of the interface. Are there other options that have a better interface?
Thank you,
Teri
I was enhancing the same, however shut everything off and restarted worked for me
teribear515,
The MX432 is not compatible with the Mojave operating system.  For details about what versions of Mac OSX the printer can be used with, visit the following link:
Mac OS X Compatibility
powered by Lithium
