09-27-2018 06:35 AM
My father has a canon scanner Lide 110 that uses MP Navigator X.
That software does not longer work with macOS Mojave, it wont even start. That sucks.
Does anyone know of a good scanning software that works with Lide 110?
Preferably software that detects multiple photos and saves them individually as jpegs.
thanks.
09-27-2018 10:25 AM
Hello.
Make sure that the latest drivers and MP Navigator versions are being used. Visit the following link to download the latest versions for Mojave:
CanoScan LiDE 110 Drivers & Downloads
If the program still does not launch correctly, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
10-18-2018 12:46 AM
I am having a similar issue. I have a MacBook Pro running macOS Mojave 10.14, and I cannot get the latest version of MP Navigator EX 5.0 to work. What is the solution? Is there another version of MP Navigator EX coming that will be compatible with Mojave 10.14? I am trying to use MP Navigator to scan from my Pixma MX870.
10-18-2018 01:22 PM
From the Mac system report / applications -- MP Navigator EX 2.1.5 that I have -- which was updated in 2017 -- is still a 32bit applicaiton.
32 bit apps will work in ver 10.13 - High sierra -- the OS will run both 32 bit and 64 bit apps. So does the older versions upto 10.8 or 10.9.
From MacOs Mojave -- Only full 64-bit applications will work ---
so only wat to get the these MP Navigator apps to ccontinue to work is to avoid upgrading to Mojave -- or roll back and INSTALL an older version of the macOs.
10-19-2018 01:29 PM
It is not possible to return to a previous operating system for me. Why have you not upgraded the Navigator app to 64-bit? It has only been out for 6 months! My next printer will be from a company that updates its software. With this debacle, it is not possible for me to scan from my MG8220 to my Mac. What is it with you people???
10-19-2018 06:43 PM
10-19-2018 06:50 PM
I purchased Vuescan which appears to work well with Mojave. With Canon, it is always a day late and a dollar short.
10-19-2018 11:42 PM
I was wrong in my earlier posting. According to Apple support site -- I read that MacOs Mojave will be their LAST VERSION of OS which will support 32 bit apps.
Hence, theorectically MP Navigator X 2.5.1 should work in Mojave also. I am not sure of earlier versions of MP navigator.
Its a shame that while 32bit and 64bit versions are available for Windows, the same is not for MacOs despite the larger user base.
I am currently using High Sierra and version 2.5.1 works well. But am scared to upgrade to Mojave and have my LIDE 700F unusable after that upgrade !!
10-24-2018 12:09 PM
10-24-2018 06:30 PM
No pop up on left side of window using MG8220.
