Reply
Occasional Contributor
Re: CanoScan LiDE 220 error > Cannot communicate with scanner Error 2, 156,182
Hi Mark,
Mine is now working, But I did have to go through the process I outlined above.
Joyaa
New Contributor
Thanks.  I uninstalled the drivers.  Then reinstalled with the CD that came with the scanner.  Got a new error, "Code: 2, 156, 182".  It's only happened once when I tried to scan more than one sheet into the same file.  Funny thing is that the first time I installed the software/drivers, I said no to the feedback questionaire.  This time I said yes and it seems to be working.  I liked my old Canoscan LIDE much better.  That thing was the Energizer bunny.  To bad It would only work with 32-bit OS.  I'll likely stay away from Canon in the future.
Driver v1.02 is posted.
History:
[Ver.1.02]
- The scan error in the certain PC has been rectified.
Maybe this will fix the scanning errorfor good.
New Contributor
[ Edited ]
Hi you all,
I reported this problem to Canon late March, with details of problem (with new computers quicker usb) and got reply that new driver will be offered on April at some point.
And now I can confirm that this thread problem is fixed, Win8&10, with usb2&usb3, by newest Canoscan Lide -driver of 13 April 2016, version 17.0.5 , so install it from Canon Support site and things work with newer computers too.
Check that you get latest software too (now from autumn 2015) and install it before installing that new driver.
When installing that newest driver, disconnect first scanner usb-cable from compuret, before installing driver.
And when driver installation asks to connect scanner, connect it then with usb-cable, so that computer with new driver recognizes scanner right.
New Contributor
Scanner (Lide 220) will not power despite several attempts to replug. I have a new Mac computerl. It worked OK with the old one. what can be the problem?
Hi Spausdinti,
What version of OS X is installed on your Mac?
Sadly, following a Windows 10 upgrade to version 1709, this problem has returned, and seems more intransigent.
Hello,
I have the same problem with Windows 10 and num error 2,156,55!!
It's my second scan Lide220, because I thought it was my scanner didn't work and brought to the shop...
Should I bring back again??
Have you tried reinsatlling the software from the original disc?  (This seems to help a little...)
Yes I did it, and I redo again reinstalling/installing !
New message error 2,156,182 :-(
powered by Lithium
