02-17-2013 06:32 AM
I run Windows 7 64 bit and use Internet Explorer 9. Printer is MG8250
Some weeks ago I downloaded Easy-webprint EX version 1.3.5.0 and it worked fine. I could get the toolbar to appear or disappear in the normal way ie via View/Toolbars then ticking or unticking its entry on the list.
Today I decided to use it for the first time in several weeks. I went through the normal process to make the toolbar appear so that I could use the software but ticking it had no effect, or at least no effect that was visible on the screen.
I then tried re-downloading the software but the situation remained the same ie I can't get the toolbar to appear.
Any ideas why the toolbar is not appearing?
02-18-2013 04:00 AM
I have managed to make the toolbar appear by doing the following:
- removed (unticked) the Google toolbar and the Easy-web toolbar appeared magically in its place.
- re-installed (ticked) the Google toolbar and it appeared in addition to the Easy-web toolbar
I can now happily hide/display the Easy-web toolbar without any need to remove the Google toolbar.
I've still no idea why i had this problem in the first place but all seems to be fine now
02-18-2013 04:00 AM
