07-10-2016 11:50 AM
Well, I took my equipment out to the race track and what a learning experiment. Now I know why I drink, haha, just kidding.
Being early evening (some natural light) in to late evening (stadium lights), cloudy, raining, bugs, flickering, under exposure, photo noise haha... One can learn a lot in a few hours.
This was my first time at night racing.
Not the best, but t least I can strive to do lots better.........
07-14-2016 09:32 AM
"MacBook Pro Laptop (early 2011)
OS X El Capitan
Version 10.11.5
Processor 2.3 GHz Intel Core i5
Memory 4 GB 1333 MHz DDR3"
I am a WIndows user so I am of little help with your Mac. I beta test software for a couple of companies and I can say there are 10 times the issues with the Mac side vs the Windows. I think it is usually an OS problem. So make sure you have the correct DVD for the OS your MacBook has. Others may be of more help here.
07-14-2016 11:21 AM
[EDIT] For example, crop a photo in DPP. Now open it in LR. It shows up cropped, and you cannot undo it, except in DPP.
I tried and it did not duplicate this behavior.
The only thing I can think of, is you chose 'Save' at the top of the Crop window in DPP, which saves a JPG copy of the file. The RAW file remained uncropped in LR.
07-14-2016 11:24 AM - edited 07-14-2016 11:24 AM
Of course, I chose "Save". If you do not, then any edits you made are immediately discarded. You proved my point.
07-14-2016 11:39 AM
No they are not. It just show that you are not really familiar with DPP. The issue is the user, not the software.
07-14-2016 11:47 AM - edited 07-14-2016 11:59 AM
You're talking about a different "Save". I'm talking about saving the edits/changes you've made to RAW files, not saving an output file. I only use cropping as an example because the results of the changes are so obvious.
Okay, if you don't like cropping, then change it to black and white. When you get ready to close DPP, and it prompts you to "Save the changes?" Click yes.
As Bob pointed out, the changes are saved in the file. Lightroom reads those changes as permanent, not temporary.
07-14-2016 12:05 PM
@Waddizzle wrote:You're talking about a different "Save". I'm talking about saving the edits/changes you've made to RAW files, not saving an output file. I only use cropping as an example because the results of the changes are so obvious.
I tried what you described, and Lightroom did NOT read those as permanent changes.
07-14-2016 02:44 PM
Cropping is one thing that is destructive in PS. It can not be put on a layer. It isn't in LR.
07-14-2016 02:57 PM
"I tried what you described, and Lightroom did NOT read those as permanent changes."
I must agree. LR didn't.
07-14-2016 03:41 PM
@ebiggs1 wrote:"I tried what you described, and Lightroom did NOT read those as permanent changes."
It does for me.
If I make edits to RAW file in DPP, and then save the changes, I immediately see those changes in LR when I open the file, but not vice versa. In particular, I had one file [a macro of a bee] that was cropped in DPP4, and I couldn't "uncrop" the file in LR6. I had to re-open the file in DPP4 and remove the cropping before it opened up cleanly in LR6.
Unfortunately, I cannot retest this until several hours from now. I have also had LR do an update about a month ago that seemed to roll back, or disable some of its' features. Most noticeable is a difference on the tab to perform lens correction in the Develop module. I now have just two sub-tabs, where I used to have four.
07-14-2016 04:07 PM
Remember I am not a DPP fan nor am I a user. I simply did what you said. I actually have no idea beyond curiosity what DPP does or doesn't do. I use it so little. When I opened it the moths flew away as I must have disturbed them.
You guys can say what you want and brag all you want. Do as much boasting as you want and DPP will never be Photoshop.
As a psuedo Lightroom, yeah, maybe but not for me. It remains a wanna-be!
