03-28-2020 01:32 PM
Not sure if this is the right place to post this! Recently bought a Canon rebel T7i... really into wildlife and birds!!! Was considering selling and buying a 7d ii
Is this a wise decision? I know the 7d is older but has a faster fps
but will the lower MP cause an issue?
03-28-2020 06:36 PM
ISO 3200
SS 1000
250mm f5.6
03-28-2020 07:04 PM
Do you shoot RAW or JPEG? I think that is good capture. Nice!
I took the liberty of adjusting exposure and leveling the horizon. Do you shoot RAW, and then use Canon's Digital Photo Professional software to create JPEG files?
03-28-2020 07:09 PM
@b1gb2olo wrote:Mainly birds currently! i posted some pictures from yesterday on my IG im not sure how to upload to a forum.
I was using a tripod yesterday.
always in manual mode, I was using smooth zone AF instead of single point which I normally use.
also on Servo ( for tracking if im correct)
metering mode also.
I would use just the center AF point, One Shot AF, Single Shot drive mode, for shooting from a tripod at a fixed subject, the bird feeder. Use Evaluative Metering mode, which is the default setting. This was not a bright sunny day, so do not expect the best results. It is what it is, and I think you did a pretty good job of it considering the shooting conditions.
In fact, I would be inclined to switch to Live View, and then use the 10x magnify mode to manually adjust for the best focus. Leave the lens in MF mode after you achieve critical focus.
03-28-2020 08:51 PM
Ive always used RAW.. I only use lightroom for editing and than export to dropbox
03-29-2020 02:33 PM
@b1gb2olo wrote:Ive always used RAW.. I only use lightroom for editing and than export to dropbox
Oh, yeah. One last tip until you get back to us. If you are shooting stills from a tripod with the camera in a fixed position, then it is advisable to turn of the IS in the lens. If the camera/lens combo is not panning on th tripod, then Canon recommends that you turn off the IS.
Some combinations of high end lenses and camera bodies can actually sense when the camera seems to be mounted on a tripod, and will disable the lens IS automatically. Your gear is not able to do that.
03-29-2020 02:45 PM
Awesome Thank you for that!!
03-29-2020 02:47 PM
Im going to stick with the t7i until atleast the come out with a newer 7d
I think my best bet though is a better mm lense
im stuck between sigma 150-600 (C)
and cannon 100-400 i since the ii is pretty pricey
03-29-2020 02:48 PM
My IG is bg.gartland i posted a few other shots yesterday i wouldnt mind feedback on!!
I cant upload to here since the files are too big!
03-29-2020 04:45 PM - edited 03-29-2020 05:08 PM
@b1gb2olo wrote:Im going to stick with the t7i until atleast the come out with a newer 7d
Given that choice, I would pick the Sigma 150-600 "C". There is no substitute for focal length when it comes to wildlife photography. Avoid buying a used one, if you can. Be sure to get a Sigma Dock, too. When I bought mine, I realized that I needed a much beefier tripod [head].
The original EF 100-400mm is reportedly nowhere near as good as the Mark II. I would be disinclined to buy a used one. BTW, avoid buying used gear on Amazon or eBay if you are not familiar with the seller. Those sites are great for buying a bread machine, but you are rolling the dice buying used big ticket items like camera gear.
03-29-2020 08:05 PM
