Search instead for
I got Error Err 01, how to fix it
marianaduran
hi. all
Communications between the camera and lens is faulty. Clean the lens contacs.
When encountering this error what should we do, I am not familiar with fixing camera errors. Please advise me on how to fix it. thank you very much
2 REPLIES 2
Ray-uk
Whiz
Although the official advice is to clean the contacts you will find that this achieves nothing, it is usually a fault within the lens. Try cleaning the lens contacts with a soft cloth, don't use anything abrasive, if that doesn't work then try fitting another lens to the camera.
ebiggs1
I can almost guarantee you that cleaning the contacts will do nothing or will it fix anything.  Can you see any physical damage to any of the contacts?  If not it probably isn't the contacts. The only real thing you can do is try another lens and also try it on a different camera.
People that don't change lenses very often or not at all are the ones that are helped by cleaning the contacts.  The act of mounting and unmounting the lens is usually enough to keep the contacts operating. It is an easy thing to do and if done correctly it won't hurt and has the small possibility it might do something. Just alcohol and a qtip.
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
03/22/2022: New firmware version 1.2.0 is available for PowerShot PICK
03/16/2022: New firmware version 1.5.2 is available for EOS-R5
03/16/2022: New firmware version 1.5.2 is available for EOS-R6
02/07/2022: New firmware version 1.1.1 is available for EOS-R3
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
12/7/2021: New firmware version 1.1.1 is available for CR-N 300
12/7/2021: New firmware version 1.1.1 is available for CR-N 500
12/2/2021: New firmware version 1.1.0 is available for RF 70-200 F4 L IS USM
