Reply
Occasional Contributor
Accepted Solution
How do I change my username?
Can't figure out how to contact a forum administrator for login assistance.  Need some help amending my username.
Moderator
Re: How do I change my username?
Hello!
You can change your user name by following these steps after logging in:
1) Click "My Settings" in the top right of the webpage.
2) If not already selected, click "Personal" then click "Username"
From here you should be able to update your user name. We hope this helps!
Thanks for your quick response. Just tried it and my username does not show up in "personal". I thought it would be something like this and have been trying to figure it out, but so far to no avail. Any other advice?
Moderator
Hi Again!
We're sorry to hear that! Send us an email at canonfriends@cits.canon.com with your details (including what you want your user name to be changed to) and we can get that taken care of for you!
Thank you so much!  Will do that right away.
New Contributor
[ Edited ]
Samantha,
Did this ever get solved? I have the same issue and will send an email.
I'm knew here so I might be doing something wrong. I saw the issue was 'Solved" and clicked on this link but it just brought up the same page with no answer.
If it was solved it would be quite convenient if the solution was posted, but that's just me.
If my email to Canon resolves the issue, I will post the solution here to help others with the same problem.
Thank you.
Highlighted
Moderator
Hi RobertJara!
Thanks for reaching out! We can change your username on the backend, as long as it's not already taken. Just send us an email at canonfriends@cits.canon.com with your details, like Samantha indicated above, and we'll get you taken care of!
Yes...this problem was solved.  Was able to contact Canon Technical Support via email and they changed the name on their end.  Hope you have the same successful results.  Best regards.
New Contributor
[ Edited ]
It's very simple bro. You can do it on your own by going to settings and there editing your account details and that will resolve your issue. If you have forgotten your username then you can check it on your mail id. <removed link per forum guidelines>
New Contributor
I see the site still doesn't allow you to change your username unless you call or email and request the name change. Wish that was fixed. I see you can change just about any IM name which seems pretty useless to me.
powered by Lithium
