07-23-2020 02:37 PM
07-24-2020 11:26 AM - edited 07-24-2020 11:27 AM
Yes.
Map Utility has been deprecated because of some licensing issues with the mapping portion. The replacement is GPS Log File Utility.
07-24-2020 07:26 AM
Welcome to the forum.
Yes, the manual is unclear on that.
Just use the same cable that came with the camera for connecting to computer. It's a USB-A to Mini-USB cable.
07-24-2020 07:39 AM
Thanks John,
I have EOS RP. This model has USB-C which I love.
I got GPS-E2 with two cables for other cameras connectivity. Long and short, but both has the same socket for pluging in to GPS unit and probably other camera models.
I am looking for a cable which can connect GPS unit ( quite rare socket) and any P/Mac with regular USB female port.
Best regards,
Sergei
07-24-2020 07:44 AM
If your computer has a USB-A connection you want the cable I described above.
The GPS has a connection port that accepts both the GPS to camera cable and a camera to computer connection cable.
07-24-2020 10:52 AM
Why do you want to connect it to a PC? I see no mention of that in the manual. I believe the logs are stored on the SD card in the camera.
07-24-2020 11:01 AM
One reason was to update for latest firmware.
I do not think GP-E2 stores logs in the camera memory card. The logs are stored at the GPS unit. That is why it can be used as a stand alone tracker, syncing and adding logs to camera after.
connecting to PC would allow save logs on computer and port those into various mapping apps, such as Google Earth.
Yes.
10-01-2020 10:10 PM
My MacBook pro does not recognize my GPS receiver so
I can't update the firmware with the GPS Log File Utility. Says no GPS connected. I have the GPS to USB-C cable.
10-01-2020 11:09 PM
Does anything connect to the MacBook with that cable?
10-09-2020 07:47 PM
No, however the Mini USB Cable USB 2.0 Type A to Mini B Cable works fine for connecting the GP-E2 to the MacBook pro.
