Reply
Respected Contributor
Re: Rain, different lights at the track, One can learn a lot pretty quick
@ilzho wrote:
Thanks for the info.
I have never used LR, PS or PSE.
I am not a pro either, but I do shoot a lot.
When I use Iphoto to PP a RAW image, I'm limited. Some of the limitations is Iphoto and some of it is myself. I have trouble PP an image and what looks ok to me, may not look to others.
I guess it's a learning curve.
One big difference between Lightroom and Photoshop, is Lightroom, is completely non-destructive. The changes you make are stored in a different file than the photo itself. So, the original unchanged file is always available. Because of this at anytime you can also go back and undo any change you've made along the way, from the first one to the last one.
Super Contributor
Thanks, Now I need to find LR at a good price haha.....
Honored Contributor
Digital Photo Professional is also completely non-destructive, but the changes are saved in the same file as the photo itself. If you don't think that's a huge advantage, try it for a while and you'll see.
Bob
Super Contributor
For some reason it will not launch on my computer. This is canon software tool that comes with a purchase right? I have the cd but it will not launch to load, frustrating.....
VIP
What type of compuer are you using?
VIP
[ Edited ]
"Digital Photo Professional is also completely non-destructive, but the changes are saved in the same file as the photo itself. If you don't think that's a huge advantage, try it for a while and you'll see."
Maybe not so huge as you think.  I can make seemingly endless non-destructive edits with either DPP or LR to a RAW file.  BUT...
1.  If I edit a file in DPP, then I will see those edits in LR and cannot remove or undo them in LR.  They are part of the file.
2.  If I edit a file in LR, then I will NOT see those edits in DPP.  But, any edits I do perform will show up as permanent in LR.
[EDIT]  For example, crop a photo in DPP.  Now open it in LR.  It shows up cropped, and you cannot undo it, except in DPP.
Super Contributor
MacBook Pro Laptop (early 2011)
OS X El Capitan
Version 10.11.5
Processor 2.3 GHz Intel Core i5
Memory 4 GB 1333 MHz DDR3
A lot of my programs drag, slow, takes 30 seconds+ to open.....
I clear my cache, little help...
I just need to take it into Apple to see what can be done....
VIP
OS X El Capitan
Version 10.11.5
I am not the MAC user, but other regulars around here are.  Describe what happens when you try to install the Canon software.
Super Contributor
I put the disk in and it spins and opens up to the setup page/icon.
I dbl click on the setup icon and it tries to open, but nothing.
I then go in to the software folder and dbl click the universal setup icon, it tries to open, but nothing.
VIP
"Maybe not so huge as you think.  I can make seemingly endless non-destructive edits with either DPP or LR to a RAW file.  BUT...
2.  If I edit a file in LR, then I will NOT see those edits in DPP.  But, any edits I do perform will show up as permanent in LR."
That is exactly correct.  It also shows how unimportant that non-destructive feature really is. PS is also non-destructive, too.  If you use layers most all, if not all, your changes are completely reversible.  Plus they can be turned on or off.
You can kid yourself and you can listen to all the hype about editing software that tries to be PS.  But in the end the number one software used by, the almost unanimous majority of, professional photographers is PS.  The closest option to full blown PS is PSE.  It is not DPP or any other post editor.  Can you get edits done or make any of the others work, of course, but if you want the best there is, it is PS and its cousin PSE.
powered by Lithium
