Reply
Highlighted
VIP
Re: I need a camera for high school sports
The most common reason for being prevented from adding photos is file size. If this is the cause, then you should have received a message saying maximum image file size is 5MB. In practice, there is some overhead. I limit files to 4.5MB.
Highlighted
VIP
You will visible noise at ISO 6400. But, LR should clean that up, provided you do not crop a whole lot.
Why not use the 70-200?
Highlighted
Respected Contributor
If you click on the photo symbol near the middle of the control bar of the edit window there is a picture icon that should let you insert an image.
High school football field lighting is generally horrible with few exceptions so noise is a fact of life.  Wrestling is usually easier because it is easier to get close to the action with a shorter fast lens and for many of those shots you can slow the shutter speed a bit.  The local high school just upgraded their gym and it has good lighting now so a standard exposure can be made at 1/640, F2.8, @ ISO 4,000  Their football field is at the other extreme and the image below was at 1/1000, F2.8, @ ISO 40,000  It was processed just using Canon DPP with no additional de-noising software.
But nothing is a substitue for good lighting and the second image was taken at an afternoon game @ 160 ISO and the only negative was the university wanted the photographers in an area where the players were often illuminated from behind but I will take backlit over "no-lit" anytime Smiley Happy
Rodger
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
Highlighted
VIP
"It won’t let me add a photo ..."
Probably too big resize it in LR. While on the subject of LR how are you doing your post editing?  You can reduce visible noise with LR.  ALso make yourself a preset that does lens correction upon import. This should be mandatory.
The T7i is a seriously good camera.  Unless you go mega bucks any other camera is only going to show minimal improvements in noise.  Don't pay any attention to folks that tell you otherwise.
Take a look at the Canon EF-S 17-55mm f/2.8 IS USM Lens for your T7i.  But even then it will be only slightly better that what you have.
Highlighted
Occasional Contributor
I haven’t been able to get on the computer and I don’t see where to add the photo on my phone.
I will look into the lens. I think I figured since the T7i is a rebel that’s entry so there has to be better...
Highlighted
@waddizzle , it’s still really new to me lol. I tried it once and felt that it was too much at matside. I should try again
Highlighted
Someone suggest the 7d mk 2, and the Canon EOS 1D Mark IV 16.1 or thr 5d mk 3 or4.
I’ve akways loved taking photos, and I think I take good ones, but now I’m doing it for the school
And want to start a little business, so I just want to make sure ... we’ll i just don’t want to suck lol
Highlighted
[ Edited ]
This is a good site to compare noise performance of different bodies at different ISO speeds:  https://www.the-digital-picture.com/Reviews/Camera-Noise.aspx?Camera=1111&Test=1&ISO=25600&CameraCom...
Your placement and the lens you use play a critical role because you want to minimize cropping to avoid accentuating the noise.  Of course this puts more pressure on you to properly frame the shot because the lens filling capture that leads to less noise in the final image puts more pressure on you to track and time the unfolding play. Lens focus speed, which is highly dependent upon the body used, is another critical component.
Rodger
Highlighted
The sigma or canon lens?
Highlighted
VIP
If you are looking for lower noise than a T7i, then you probably would want a 5D series out of those choices.  Even a 6D or 6D2 would be a significant improvement.  But, LR should be able to clean up your current photos a LOT, enough to gain at least a full stop in improvement.  You could sacrifice resolution, and get rid of ALL of the noise if you wanted.
powered by Lithium
