Cannon EOS 70d v Cannon EOS R50
Rgauden
I was planning on originally getting the cannon 70D but heard to look into something different. I found the R50 for like $20 more and was wondering if that’s the better choice? Thanks for the help.
3 REPLIES 3
rs-eos
Do you have any existing lenses? If so, what kind? For example, if you have EF or EF-S and opt to going with the EOS R50, you'd need an adapter ($99).
If you're starting new, the EOS R50 would be the way to go.  Be sure to budget lenses.  Look at either RF-S or RF lenses.
Ricky
I don’t have any lenses yet, if I were to get the cannon 18-55mm and the cannon 70-200 would I need an adapter
If you're looking at RF lenses (e.g. the RF-S 18-45mm; note that this RF version only goes to 45mm), you do not need an adapter.  Since you're starting new, I'd strongly recommend sticking with RF lenses.
However, if you're on a budget and want to pick up potentially cheaper EF-S or EF lenses, then yes, you'd need an adapter for those.
Ricky
