10-07-2016 12:24 AM - edited 10-07-2016 07:07 AM
I own a 60D my only DSLR, I’m thinking about buying an 80D. my 60D would be a backup then. Is a 80D worth the upgrade? thanks, Blair
10-07-2016 02:15 PM - edited 10-07-2016 02:34 PM
@Peter wrote:The sensor is better. Less noise, 13 EV of dynamic range vs 11,5 EV at ISO 100, 7 fps vs 5 fps, 45 af points vs 9 af points, faster write speed to the SD card: 85 MB/s vs 21 MB/s.
I knew it has a better sensor but did not know about improved dynamic range. I also like the 45-point all cross-type AF system....Allowing me to shoot in low light levels is a plus for me, I have a birdbath and they come at dusk.
10-08-2016 03:17 PM - edited 10-08-2016 03:18 PM
@Peter wrote:If I don´t remember it wrong [Brand N] had some thingy in the past about cutting the lowlight. Something that made it an issue to take pictures of stars.Brand N bakes in two things into their RAW files that Canon didn't in the past. Both of them impact Astrophotographers. One of them is the Black Point and the other is a median like noise reduction filter.
These two things baked into the RAW file were the most significant reason why Brand N scored better in the testing companies DR tests.
Google: Black Clipping hack Brand N* for Astrophotographers
Google: Brand N* Mode 3 work around
* when Googling replace 'Brand N' with the appropriate company name
10-08-2016 10:21 AM
10-09-2016 10:16 AM
