09-12-2014 11:34 PM
I have a relatively new 70D and used it with brand new Tamron 16-300 lens. Had trouble with autofocus under easy conditions. Was provided another lens and had less trouble. Then used with old Canon 70-200 2.8 IS and now notice same issue. Times that focus should be easy the camera doesn't search, it just does nothing as I push the shutter half way. I snap a shot or two out of focus and that seems to actuate the focusing. Sometimes I can zoom clear in to 16, and that seems to jar it into action. I now think the problem is not the lens choice, but the camera. Has anyone experienced this problem? Any thoughts?
09-13-2014 08:46 AM - edited 09-13-2014 02:57 PM
There may be a clue in the fact that it happens with your 70-200. My 70-200 f/2.8L IS II exhibits the same behavior if I try to focus on a subject that's too close. That lens has two separate settings, one of which lets you focus closer but with (I believe) slightly lower reliability.
09-13-2014 10:45 AM
09-13-2014 04:25 PM
01-10-2016 09:16 AM
Hello Jerry,
I found this old post by googling the symptoms I just observed on my setup, and found I'm exactly in your same condition!
I own a Canon EOS 70D and a Tamron 16-300mm f/3.5-6.3 Di II VC PZD MACRO lens since exactly 1 year, and during my recent travel I stumbled upon this annoying behavior: sometimes the autofocus gets stuck, and the shutter release button just won't work. I tried to zoom in and out and to refocus on a different point, and to switch the lens from AF to MF and back, and eventually the camera waked up, but I had not clues about what happened or what behavior unjammed the camera.
What I noticed is that even if the shutter release button didn't work, the lens was actually focused: by switching it to MF I was able to take focused pictures.
Did you find a solution? Do you know whether the guilty is the camera or the lens?
Thank you!
Bye,
Marco
01-10-2016 01:32 PM
The Tamron 16-300mm f/3.5-6.3 Di II VC PZD MACRO lens is a fairly new Tamron lens. It should work well on a Canon crop cameras like the 70D. Have the camera checked out.
05-18-2016 10:14 AM
I've been using the Tamron 16-300 with Rebel 5ti exclusively for 2 weeks now to check it out in all ranges and just last night and again this morning, I also experienced the autofocus issue. I tried setting different lengths, switching between manual and autofocus, turning off/on, etc and haven't found anything that seems to work consistently. It isn't swimming -- it just doesn't do anything with shutter half-pressed. I'm using single focus so I can make sure I'm finding a strong contrast area to direct it to and one-shot. Will clean the camera and test with other lenses to see if I've developed AF problems with those to try to narrow down the problem but will keep digging to see if this is a known defect. Lens may be finding its way back to Tamron. :-(
05-18-2016 12:00 PM
@jmitsch wrote:I've been using the Tamron 16-300 with Rebel 5ti exclusively for 2 weeks now to check it out in all ranges and just last night and again this morning, I also experienced the autofocus issue. I tried setting different lengths, switching between manual and autofocus, turning off/on, etc and haven't found anything that seems to work consistently. It isn't swimming -- it just doesn't do anything with shutter half-pressed. I'm using single focus so I can make sure I'm finding a strong contrast area to direct it to and one-shot. Will clean the camera and test with other lenses to see if I've developed AF problems with those to try to narrow down the problem but will keep digging to see if this is a known defect. Lens may be finding its way back to Tamron. :-(
As I pointed out to the Original Poster almost two years ago, that symptom is easily explained if the camera is positioned too close to the subject.
05-18-2016 12:19 PM
Have you tried turning of the OS, Optical Stabilization, or whatever it is Tamron calls it?
As a last resort, turn off the lens' AF and OS switches, dismounting the lens, and replacing it after a minute?
05-18-2016 12:32 PM
I wish it was that simple. I have been testing at all ranges after having first experienced it when trying to focus at 300mm and thought that maybe it just didn't like being extended that far.
