Reply
New Contributor
Accepted Solution
trouble with 70D viewfinder
My 70D viewfinder has numerous vertical lines and I can't access any menu settings. Help.
Esteemed Contributor
Re: trouble with 70D viewfinder
Viewfinder or lcd?
Sounds like you might have the grid display on, though that should not just be vertical lines.
New Contributor
It's not the grid display. It definitely is something to do with the sensor.
Since the sensor data does not show up in the viewfinder, you need to re-phrase your question.
New Contributor
Thanks. I really don't know how to describe it. I'm just guessing it's the sensor. The lines are white, blue and some other colors. They are very close together.
If it shows up in the images, you can post it here.
Super Contributor
Try connect your 70D to Canon EOS utility and see how it works from there.
It could possibly be a loose wire of the LCD.
powered by Lithium
