Reply
New Contributor
replacement battery for Canon 1Ds MkIII; new LP-E4n?
Hello all,
I need a replacement batteries for my Canon 1Ds MkIII; can I use the new LP-E4n? With the same charger?
Thank you in advance.
Esteemed Contributor
Re: replacement battery for Canon 1Ds MkIII; new LP-E4n?
I found this
http://www.the-digital-picture.com/Reviews/Canon-LP-E4N-Battery-Pack-Review.aspx
Which suggests that it will only charge to about 90% with the charger you & I have, A newer charger will be required for 100% My calculator says that instead of getting 2450 mAh you' be hoping for 2205 mAh which is a bit shy of the correct battery we're already using.
New Contributor
If then, the battery is not fully charged, can we presume that it not last as long in terms of years?
I really don't know whether it would or not. It certainly won't make it last longer but whether it would shorten it's life much is hard to tell.
powered by Lithium
