05-21-2013 01:56 AM
my 1D mark II is acting up. I've just found out that all of my photos taken by my 1D mark II are containing a whiteout area in the middle when setting the shutter speed at 1/50 or faster (the faster the speed, the larger the whiteout). Do any of you know what is the cause and how to fix it? Thanks a lot.
05-21-2013 11:24 AM
05-21-2013 07:56 AM
Most likely you need the shutter replaced.
05-21-2013 11:24 AM
05-21-2013 11:42 AM
My answer is not based on personal experience but from seeing similar samples with similar questions as to cause at another forum. Hopefully I'm wrong but I don't think so based on the sharp inverted V on the left edge of the problem area.
