07-07-2016 02:57 AM
My 7d does not recognize all of my compact flash cards not the CF adapter for SD. Any suggestions
07-07-2016 09:08 AM
CF adapters can be a problem. If it's reading real CF cards then the camera is working properly.
07-07-2016 09:40 AM
Buy only top quality cards from a good retailer. But anybody can get a faulty card and they do go bad occasionally.
07-07-2016 04:28 PM
It recognizes none of them, or do some work?
07-07-2016 05:34 PM
Some of the cards will work some not, I have tried them in my 20D and some of the cards that did not work in the 7d will work in the 20D, It all seem to happen at once had been uililizing a CF Adapter Big Gear with a 128 gb micro high speed worked great
07-07-2016 05:43 PM
You might try to peak inside to see if any of the pins are bent.
07-07-2016 05:45 PM
"CF Adapter Big Gear:"
What is this? Any adapter is a bad idea. Never use any adapter. Use the cards as they come.
07-07-2016 05:46 PM - edited 07-07-2016 05:47 PM
Bent pin(s) was my thought, but OP says some work and some don't.
07-07-2016 05:49 PM
Can't hurt to look....
07-07-2016 05:51 PM
Agree.
