Reply
Highlighted
New Contributor
looking at picture
I have taken a photo about an hour ago, and when I went to look at the screen says busy, the camera has done this before however has only stayed on for a few seconds l, this time however it has stayed for over and hour. I can't look at photos or turn it off.
What can I do !?
Highlighted
Reputable Contributor
Re: looking at picture
[ Edited ]
On/off-button is a is just a software power off button. Remove the battery.
What kind of camera and what version of firmware do you have?
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 85/1.8, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
Highlighted
Respected Contributor
[ Edited ]
Did you happen to set the camera to bulb? You may just have to press the shutter button a second time.
Highlighted
[ Edited ]
Possible if she has taken a bulb picture for about one hour in duration and used noise reduction for long exposure.
Just pressing bulb once without keeping it pressed will just take a picture.
Highlighted
New Contributor
I had used the camera a few seconds before and hadn't changed anything, I was able to take photos afterwards still but was not able to see them
Highlighted
So, what about firmware, camera model and what has happend after you removed the battery?
Highlighted
My mistake. Other cameras I've owned had one press to open the shutter during a bulb exposure then a second press to close.
However, accidentally turning on mirror lockup can mimic the same thing. First press locks up the mirror, which can be confused with taking a picture.
Highlighted
VIP
All of that is not what is wrong!  Sorry.  One 'cheap' possibility is the SD card is corrupted.  The other more expensive one is it has failed and will need repair.
powered by Lithium
