01-23-2015 01:39 PM
I recently was forced to upgrade to a Canon 70D after my 50D died from a fall. I am not happy with the ease of setting the Shutter speed while in Manual mode. The only way I can currently set the shutter speed while in Manual mode, is to go to the info screen and set the shutter speed with the touch screen. The manual states that I should be able to set the Shutter speed with the Main Dial, behind the shutter release. ( which is how it was on the 50D). I can control the Aperture with the quick control dial. The Function Lock button is off.
I am sure this is do to some setting I have wrong, that is not allowing me to fix this issue, but I cant figure out what it could be after hours on the net and in the manual. I would greatly appreciate it if someone could help me with this issue.
Thanks
Gene
01-23-2015 02:41 PM
It shouldn't have this behaviour. Try reset the camera to default and see how it works out.
01-23-2015 02:59 PM
BTW, did you customize the dials ? Go to the the C.Fn III and final out what you have done with the main dial - assign it to AV ?? etc
details here : http://blog.dojoklo.com/2013/08/15/canon-70d-tips-and-tricks-custom-controls/
01-23-2015 03:46 PM
Thanks for the reply.
I did go to the custom controls and clear the settings. But that did not fix the issue. I still have no control of the sutter speed in Manual mode with the Main Dial.
You mentioned resetting the camera. I can not find a method to do that in the manual. Suggestions?
01-23-2015 04:12 PM
Ok further update.
I went into the Custom Functions section and reversed the control of the Aperture control and the shutter control to the Main dial. Still have no response on the main dial. I have a Feeling that there is a problem with the main dial, not an issue with a control setting.
01-23-2015 04:24 PM - edited 01-23-2015 04:25 PM
did you do this : clear all camera settings (different from custom controls)
01-23-2015 04:24 PM
It's in P.61 of the manual.
01-23-2015 04:41 PM
More related info in the manual.
01-24-2015 12:21 AM
Another possible solution is to use a battery grip on your 70D and see if the dial on the grip will change the shutter speed.
There are some discussions about this problem on some earlier models Canon DSLR. Check it out.
http://www.dpreview.com/forums/thread/2638326
01-24-2015 09:41 AM
Gene,
Do other functions of the SS dial work? Clearing all settings and/or clear custom functions are the only real reset that can easily be done to the 70D.
The lock switch must be down and if it is and still the SS doesn't work you will need to have it serviced.
