Reply
New Contributor
gimbal for 7dm2? and a few other questions...
Hi all, I'm new to the page. I am still learning, and would appreciate some help. One of my favorite things to do is to video birds in flight. My husband is a master falconer, so i get to be up close and personal with the hawks and falcons. The birds can be flying right at my feet, or a few hundred yards away. I currently am using my 7d m2 with 70-200 2.8 IS USM. hand held it can get pretty jumpy. So i am looking into hand held gimbal mounts. but i am having trouble finding ones that will mount the camera AND support it software wise. Any ideas?
I also would like to obtain a microphone, i am currently looking at the tascam dr-10sg. It seems to suit what i will be doing. Thoughts?
final question, if you were able to video these birds, what would your choice of lens and gimbal? or no gimbal at all? what would you have your settings at as well for the camera?
thank you for your time and help.
VIP
Re: gimbal for 7dm2? and a few other questions...
I am not sure what you mean or looking for when it comes to a gimbal and software.
If I wanted to shoot video, then my first choice is a video head and a video tripod.  Video tripods lack a center column, which requires the legs to have a wider, more stable stance compared to the typical tripod used for photography.  Some of the best tripods for photographers are built like video tripods without a center column, but use a flat place instead of a video bowl.
I cannot find that Tascam model number.  Similar model numbers are audio recorders, which would still need a microphone to make a compete audio recording system.  This recorded audio would be independent of your recorded video, which creates the problem of combining the two recordings and synchronizing them.  A Rode Wireless Go system might be simpler.
VIP
What you probably want is a gyroscope stabilizer with a encoder.  I picked one up at my local camera store one time. I put it down quickly but they are amazing. I am sure they require a bit of getting used to it. I think it was around $800 bucks. I am no video shooter so I am not any real help.
New Contributor
i am looking at the Zhiyun crane 2 and the DJI ronin s if that helps you understand what i am needing/wanting. i cannot use a true tripod, as that would create a disaster trying to move it to follow the birds in flight Smiley Happy
These two video gimbals i mentioned above can support the weight of my camera, 7dm2 and a 200L, but i am getting conflicting reports as to whether or not the software from both gimbals will communicate with the 7dm2 and the 200. manufacturers say no, users say yes. so i was hoping for some clarification from someone on this site.
the tascom can be found here
https://www.amazon.com/dp/B01EO65QCM/?coliid=I28QPC0IMRCF8B&colid=3IDNPAP0DZ912&psc=1&ref_=lv_ov_lig...
thanks for your help.
VIP
The one at my camera store had a 5D Mk III on it.  I do not know if it was camera specific.
VIP
Instead of buying from Amazon where no one knows anything try B&H or Adorama.  They will have people that can tell you what you need. And, what will work with your gear.
Frequent Contributor
[ Edited ]
My gimbal head is used on a tripod, has been used for some birds in flight, and has no software or electronics. It is a now-long-discontinued Kirk Enterprises King Cobra. I do not see how a tripod can be a "disaster" for following birds in flight. The reason, or, at least, my reason, for using the gimbal, is to enable tripod support while following action.
The gimbals you are specifying seem to be specialized video devices, unfamiliar to most users of this forum. You may have better luck asking your questions in a different forum, perhaps? I am not meaning to seem negative or cynical. Smiley Happy
Even though I have a pair of 7D Mark II cameras, I have not used them for BIF. (Birds-In-Flight) I bought them for their much-improved low-light AF capability, their ability to deal so decisively with flickering light sources, their resistance to liquid and dust intrusion, and cleaner images at higher ISO settings. IOW, rough duty* use. I have shot video with neither of them; video remains a mystery, to me, except for casual video with iPhones.
Your video shooting of raptors in flight seems fascinating. Smiley Happy
A Barred Owl "told" me that 300mm is long enough, but that an unstabiliazed 300/4 lens is silly, after sundown, so I bought a pre-owned, pre-II EF 300/2.8L IS, last year. Of course, this evening shooting is not BIFs, as one usually cannot see far enough. I would like to try using IR photography to capture Eastern Screech Owls, as they call, in the nearby trees. We may erect some nest boxes, next year, which may attract either Screech Owls or Whistling Tree Ducks.
A new local favorite, which we are learning to find, is the Crested Caracara. There are local Bald Eagles, too, but we keep missing them.
*The 7D Mark II, the EF 100/2.8L Macro IS, a set of 600EX-RT Speedlites, and the Canon Macro Ring Lite flash, are, arguably, the best combination of gear, in the world, for evidentiary/forensic/crime scene photography, which was part of my duties, from 2010 to early 2018.
VIP
”The gimbals you are specifying seem to be specialized video devices, unfamiliar to most users of this forum. You may have better luck asking your questions in a different forum, perhaps? I am not meaning to seem negative or cynical.”
I have been wondering the same thing. How do you track BIF with a gimbal stabilizer?
VIP
These gimbals do not prevent movement, they simply stabilize it.
VIP
“These gimbals do not prevent movement, they simply stabilize it.”
With the camera balanced parallel to the horizon. How are supposed to track a bird with two hands the gimbal?
powered by Lithium
