06-11-2017 07:03 PM
...on the 60D do I not hear a beep or see a green light when I am in focus? Is there a setting to change this? The lens I am using is a Canon 18-135.
06-11-2017 09:15 PM - edited 06-11-2017 09:29 PM
@pixeltaker wrote:...on the 60D do I not hear a beep or see a green light when I am in focus? Is there a setting to change this? The lens I am using is a Canon 18-135.
If the light metering system is inactive and idle, then you will not hear a focus confirmation beep.
06-11-2017 09:20 PM
This is just the way Canon cameras are designed, when you're in Manual focus mode, you're on your own.. Some cameras like Sony will tell you and this is handy if you have a manual focus only lens.
The way the Canon cameras work is actually the way I personally prefer it because I have all AF-capable lenses and when I think I can do better than the AF, I go on manual focus and it does not matter what the camera thinks. A trick I use to manually focus better than the camera AF is to turn on live view, press the magnifying glass twice to get 10X zoom and focus on the magnified image. Press it again to go back to normal live view.
06-14-2017 11:18 AM
Thanks for this info.
06-14-2017 11:48 AM
Not all cameras. While this could be a Rebel thing, on my T6S it does give focus confirmation:
And on my late, great T3i, the beeper would sound:
06-14-2017 11:52 AM
Thank you for your response, but I do not have a Rebel. I have a 60D. I have used the tecnique as posted by someone else. Set the zoom to where you want it. Go to Live View, zoom in and manual focus from Live View. I tried that the other night and it works perfectly, although no beep or green light. But I was able to see close-up how sharp (or not!) I was focusing!
06-14-2017 12:21 PM
I was just correcting the "It is just not a Canon thing", it appears that it is not a Canon professional thing.
06-14-2017 12:26 PM
You should get a focus confirmation light and focus point flashing in red, just no beep:
06-14-2017 02:29 PM
I use back-button focus. Shouldn't it work with that also?
06-14-2017 03:25 PM
I don't know. Should be easy to try.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
